Udoo neo Arduino
Discussion in 'Arduino IDE' started by Ayeed Shaikh, May 21, 2016.
  1. Ayeed Shaikh
    Ayeed Shaikh Member
    Mar 9, 2016
    52
    I m facing with this error Board at COM1 is not available I am using ardunio ide 1.6.5 preinstalled in udoobuntu 2.0 rc desktop trying to connect my adafruit ultimate GPS rx and tx in pin 0 and 1 GND and 3v3 pin in my udoo neo board I have downloaded the library of GPS from git and copied it in ardunio library folder. I am new with this can any one help me.
    2,260
    564
    The arduino side is not on COM1 but on /dev/ttyMCC so set your IDE to that (as it is preinstalled).
    Second, to talk with your GPS shield from Arduino side you better use the build in Serial0, available on pin 0 and 1. Perhaps you have to modify some sketches and libraries to adapt to this situation.
    If you want to talk from the Linux side to the Arduino side you use Serial. If you want to use the GPS data on the Linux side you first read them with Serial0 from shield to Arduino and then send them with Serial to the Linux side.
    See also the communication part of the Neo documentation.
  3. Ayeed Shaikh
    Ayeed Shaikh Member
    Mar 9, 2016
    52
    Thank you will try and let you know.
  4. Ayeed Shaikh
    Ayeed Shaikh Member
    Mar 9, 2016
    52
    need some help.
    im trying to run a basic script with related to adafruit ultimate GPS but as udoo neo not supported with SoftwareSerial I dont know what to do
    SoftwareSerial mySerial(3,2);
    Adafruit_GPS GPS(&mySerial);
    I am unable to get any values on ttyMMC
    getting an error
    Kindly help me.
  5. waltervl
    2,260
    564
    You have to erase all SoftwareSerial references and use Serial0 instead.
    Change your code with
    Adafruit_GPS GPS(&Serial0);
    Be sure you connect the TX and RX pins of your gps to pin 0 and 1 (not sure I have the correct order, could be the other way) please check the documentation yourself.
  6. Ayeed Shaikh
    Ayeed Shaikh Member
    Mar 9, 2016
    52
  7. Ayeed Shaikh
    Ayeed Shaikh Member
    Mar 9, 2016
    52
    I connected Rx and tx to pin 0 and 1 and trying to run this code it successfully uploads but no output
    #include <Adafruit_GPS.h>
    String NMEA1;
    String NMEA2;
    char c;
    void setup(){
      Serial.begin(115200);
      Serial.println("Adafruit GPS library basic test!");
      GPS.begin(9600);
      GPS.sendCommand("&PGCMD,33,0*6D");
      GPS.sendCommand(PMTK_SET_NMEA_UPDATE_10HZ);
      GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
      //GPS.begin(9600);
      //GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_ALLDATA);
      delay(1000);
    void loop(){
      readGPS();
    void readGPS()
      while(!GPS.newNMEAreceived())
      c=GPS.read();
      GPS.parse(GPS.lastNMEA());
      NMEA1=GPS.lastNMEA();
      c=GPS.read();
      NMEA2=GPS.lastNMEA();
      Serial.println(NMEA1);
      Serial.println(NMEA2);
  8. waltervl
    2,260
    564
    I looked in the Adafruit_GPS library and it is full of references to softserial. So this could be an issue.
    To get rid of the library first what happens if you run the following code? Do you see GPS data arriving in the Serial Monitor
    void setup() {
      Serial.begin(115200); // setup serial for serial monitor
      delay(100);
      Serial.println("GPS test Started");
      // GPS Setup
      serial0.begin(9600);  // adapt speed for your GPS, try 4800 if ails
      delay(100);
      // Cut first gibberish
      while(serial0.available())
        if (serial0.read() == '\r')
          break;
    void loop()
      String s = checkGPS();
      if(s && s.substring(0, 6) == "$GPGGA")
        Serial.println(s);
    // Check GPS and returns string if full line recorded, else false
    String checkGPS()
      if (serial0.available())
        char c = serialGPS.read();
        if (c != '\n' && c != '\r')
          stringGPS  = c;
        else
          if (stringGPS != "")
            String tmp = stringGPS;
            stringGPS = "";
            return tmp;
      return false;
  9. Ayeed Shaikh
    Ayeed Shaikh Member
    Mar 9, 2016
    52
    will check and let you know in 10mins
  10. Ayeed Shaikh
    Ayeed Shaikh Member
    Mar 9, 2016
    52
    getting an error serial0 not declared in the scope
  11. waltervl
    2,260
    564
    Type error my side: serial0 should be Serial0.
    I adapted this script without IDE.....
  12. Ayeed Shaikh
    Ayeed Shaikh Member
    Mar 9, 2016
    52
  13. Ayeed Shaikh
    Ayeed Shaikh Member
    Mar 9, 2016
    52
    Arduino: 1.6.5 (Linux), Board: "UDOO Neo (Cortex M4)"
    gps.ino: In function 'void setup()':
    gps:8: error: 'serial0' was not declared in this scope
    gps.ino: In function 'String checkGPS()':
    gps:30: error: 'serialGPS' was not declared in this scope
    gps:33: error: 'stringGPS' was not declared in this scope
    gps:37: error: 'stringGPS' was not declared in this scope
    In file included from /usr/share/arduino/hardware/UDOO/solox/variants/udooneo/Arduino.h:26:0,
    from gps.ino:1:
    gps:45: error: converting to 'String' from initializer list would use explicit constructor 'String::String(int, unsigned char)'
    This report would have more information with
    "Show verbose output during compilation"
    enabled in File > Preferences.
  14. waltervl
    2,260
    564
    You did not change all serial0 into Serial0
    Furthermore it was an old sketch I found somewhere on the net and modified a little hoping it would compile. But debugging is an task you have to be able to do yourself.
  15. Ayeed Shaikh
    Ayeed Shaikh Member
    Mar 9, 2016
    52
    can you check with this atleast
  16. waltervl
    2,260
    564
    stringGPS was not declared yet. Add a line at the beginning of the sketch to declare it:
    String stringGPS ="";
  17. Ayeed Shaikh
    Ayeed Shaikh Member
    Mar 9, 2016
    52
    not working yet
  18. waltervl
    2,260
    564
    You have to be more specific what is not working?
  19. Ayeed Shaikh
    Ayeed Shaikh Member
    Mar 9, 2016
    52
    Wait will send you the error.
  20. Ayeed Shaikh
    Ayeed Shaikh Member
    Mar 9, 2016
    52
    I only need to retrieve speed from my gps and display it into udoo.
