Hi, I have UDOO QUAD board and since yesterday it is not booting. I have tryed Connecting Via Serial Cable and it stops at "Net:" "U-Boot 2015.10-00061-g68849f9 (Jan 08 2016 - 17:01:43 +0100) CPU: Freescale i.MX6Q rev1.2 at 792 MHz Reset cause: POR Board: UDOO Quad DRAM: 1 GiB MMC: FSL_SDHC: 0 *** Warning - bad CRC, using default environment No panel detected: default to HDMI Display: HDMI (1024x768) In: serial Out: serial Err: serial Net:" Does any one have any idea what can be wrong. What can I do? Thanks, Gašper
Bad SD card? This is the most common source of startup failures. So try another SD card to upload the image. See also https://www.udoo.org/docs/Getting_Started/Create_A_Bootable_MicroSD_card_for_UDOO_QUAD-DUAL.html
