Udoo Quad on 1024x600
Discussion in 'Android' started by Alex1234, Feb 14, 2015.
  1. Alex1234
    Alex1234 New Member
    Feb 8, 2015
    I have spent many hours of my time trying to get a hdmi screen of 1360x768 to get working. I have not succeed in that. For my project i had bought a 7" 1024x600 lcd screen with touchscreen. The screen is now on its way to me, but i would like to get things started.
    I have read several post about the nasty problems with the screen resolution. the only resolution i have found that is working is 1920x1032 and 598x480. Why is it so damm hard to get those resolutions to work?
    I gave up fixing this problem in the current compiled android so I am downloading the kernel now and will try to makes some changes there and recompile. As stated by:
    https://community.freescale.com/thread/286878
    http://www.solid-run.com/community/topic1634.html
    https://community.freescale.com/thread/306901
    Apart from that:
    When will the power button be implemented, it's very annoying that i cant shut down!
    Why did the udoo designers used such extreme hard to find lvds connector? In my opinion it should be more easy to use another brands screen.
  2. Alex1234
    Alex1234 New Member
    Feb 8, 2015
    I am not able to compile. The manual for this procedure, found in the start manual of udoo, is wrong at a few point:
    1: ncurses is not able for download
    2: The manual states: "Once completed these steps, in “udoo-dev” folder there will be 3 binary files: File System, U-Boot and Kernel." but when i have done those steps i have multiple FOLDERS named: 4.4.2, arm-fsl-linux-gnueabi and kernel with the u-boot file.
    What to do?
  3. Alex1234
    Alex1234 New Member
    Feb 8, 2015
    Can somebody help me getting this compiler to work?
  4. idorel77
    idorel77 Member
    Jul 25, 2014
    131
  5. Alex1234
    Alex1234 New Member
    Feb 8, 2015
    While trying to compile the android system image ( with: make -j4), I get these errors: What is going on?
    including ./tools/external/fat32lib/Android.mk ...
    build/core/Makefile:32: warning: overriding commands for target `out/target/product/udoo/system/xbin/su'
    build/core/base_rules.mk:529: warning: ignoring old commands for target `out/target/product/udoo/system/xbin/su'
    build/core/Makefile:32: warning: overriding commands for target `out/target/product/udoo/system/etc/permissions/android.software.live_wallpaper.xml'
    build/core/base_rules.mk:529: warning: ignoring old commands for target `out/target/product/udoo/system/etc/permissions/android.software.live_wallpaper.xml'
    PRODUCT_COPY_FILES device/fsl/sabresd_6dq/fstab.freescale:root/fstab.freescale ignored.
    No private recovery resources for TARGET_DEVICE udoo
    host C++: validatekeymaps <= frameworks/base/tools/validatekeymaps/Main.cpp
    host C++: libinput <= frameworks/native/libs/input/Input.cpp
    host C++: libinput <= frameworks/native/libs/input/InputDevice.cpp
    host C++: libinput <= frameworks/native/libs/input/Keyboard.cpp
    /home/alex/Downloads/udoo-dev/4.4.2/prebuilts/gcc/linux-x86/host/i686-linux-glibc2.7-4.6/bin/../lib/gcc/i686-linux/4.6.x-google/../../../../i686-linux/bin/as: error while loading shared libraries: libz.so.1: cannot open shared object file: No such file or directory
    make: *** [out/host/linux-x86/obj/EXECUTABLES/validatekeymaps_intermediates/Main.o] Error 1
    make: *** Waiting for unfinished jobs....
    make: *** [out/host/linux-x86/obj/STATIC_LIBRARIES/libinput_intermediates/InputDevice.o] Error 1
    make: *** [out/host/linux-x86/obj/STATIC_LIBRARIES/libinput_intermediates/Keyboard.o] Error 1
    make: *** [out/host/linux-x86/obj/STATIC_LIBRARIES/libinput_intermediates/Input.o] Error 1
    alex@ubuntu:~/Downloads/udoo-dev/4.4.2$
  6. Alex1234
    Alex1234 New Member
    Feb 8, 2015
    It does work a lot beter in ubuntu 10.04. but after some time compiling i got these errors:
    host C: mkfs.ubifs <= external/mtd-utils/mkfs.ubifs/compr.c
    In file included from external/mtd-utils/mkfs.ubifs/devtable.c:47:
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.h:48:23: error: uuid/uuid.h: No such file or directory
    In file included from external/mtd-utils/mkfs.ubifs/lpt.c:23:
    In file included from external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c:23:
    external/mtd-utils/mkfs.ubifs/compr.c:28:23: error: lzo/lzo1x.h: No such file or directory
    In file included from external/mtd-utils/mkfs.ubifs/compr.c:33:
    In file included from external/mtd-utils/mkfs.ubifs/mkfs.ubifs.h:54,
    external/mtd-utils/mkfs.ubifs/ubifs.h: In function ‘ubifs_idx_branch’:In file included from external/mtd-utils/mkfs.ubifs/mkfs.ubifs.h:54,
    external/mtd-utils/mkfs.ubifs/ubifs.h:427: warning: pointer of type ‘void *’ used in arithmeticexternal/mtd-utils/mkfs.ubifs/ubifs.h:427: warning: pointer of type ‘void *’ used in arithmetic
    In file included from external/mtd-utils/mkfs.ubifs/mkfs.ubifs.h:55,
    external/mtd-utils/mkfs.ubifs/key.h: In function ‘key_write’:In file included from external/mtd-utils/mkfs.ubifs/mkfs.ubifs.h:55,
    external/mtd-utils/mkfs.ubifs/key.h:148: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/lpt.c: In function ‘pack_pnode’:
    external/mtd-utils/mkfs.ubifs/lpt.c:219: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/lpt.c:236: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/lpt.c: In function ‘pack_nnode’:
    external/mtd-utils/mkfs.ubifs/lpt.c:252: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/lpt.c:268: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/lpt.c: In function ‘pack_ltab’:
    external/mtd-utils/mkfs.ubifs/lpt.c:284: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/lpt.c:293: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/lpt.c: In function ‘pack_lsave’:
    external/mtd-utils/mkfs.ubifs/lpt.c:308: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/lpt.c:315: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/lpt.c: In function ‘create_lpt’:
    external/mtd-utils/mkfs.ubifs/lpt.c:432: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/lpt.c:484: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/lpt.c:516: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/lpt.c:541: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/compr.c: In function ‘lzo_compress’:
    external/mtd-utils/mkfs.ubifs/compr.c:89: error: ‘lzo_uint’ undeclared (first use in this function)
    external/mtd-utils/mkfs.ubifs/compr.c:89: error: (Each undeclared identifier is reported only once
    external/mtd-utils/mkfs.ubifs/compr.c:89: error: for each function it appears in.)
    external/mtd-utils/mkfs.ubifs/compr.c:89: error: expected ‘;’ before ‘len’
    external/mtd-utils/mkfs.ubifs/compr.c:92: error: ‘len’ undeclared (first use in this function)
    external/mtd-utils/mkfs.ubifs/compr.c:93: warning: implicit declaration of function ‘lzo1x_999_compress’
    external/mtd-utils/mkfs.ubifs/compr.c:96: error: ‘LZO_E_OK’ undeclared (first use in this function)
    make: *** [out/host/linux-x86/obj/EXECUTABLES/mkfs.ubifs_intermediates/lpt.o] Error 1
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c: In function ‘prepare_node’:
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c:712: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/compr.c: In function ‘init_compression’:
    external/mtd-utils/mkfs.ubifs/compr.c:198: error: ‘LZO1X_999_MEM_COMPRESS’ undeclared (first use in this function)
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c: In function ‘write_leb’:
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c:731: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c: In function ‘do_pad’:
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c:759: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c:762: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c:777: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c:781: warning: pointer of type ‘void *’ used in arithmetic
    make: *** [out/host/linux-x86/obj/EXECUTABLES/mkfs.ubifs_intermediates/compr.o] Error 1
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c: In function ‘add_node’:
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c:958: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c:959: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c: In function ‘add_file’:
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c:1224: warning: pointer of type ‘void *’ used in arithmetic
    In file included from external/mtd-utils/mkfs.ubifs/devtable.c:49:
    external/mtd-utils/mkfs.ubifs/hashtable/hashtable_itr.h: At top level:
    external/mtd-utils/mkfs.ubifs/hashtable/hashtable_itr.h:32: warning: no previous prototype for ‘hashtable_iterator_key’
    external/mtd-utils/mkfs.ubifs/hashtable/hashtable_itr.h:41: warning: no previous prototype for ‘hashtable_iterator_value’
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c: In function ‘add_idx_node’:
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c:1643: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c:1644: warning: pointer of type ‘void *’ used in arithmetic
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c: In function ‘write_super’:
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c:1902: warning: implicit declaration of function ‘uuid_generate_random’
    external/mtd-utils/mkfs.ubifs/mkfs.ubifs.c:1906: warning: implicit declaration of function ‘uuid_unparse_upper’
    make: *** [out/host/linux-x86/obj/EXECUTABLES/mkfs.ubifs_intermediates/devtable.o] Error 1
    make: *** [out/host/linux-x86/obj/EXECUTABLES/mkfs.ubifs_intermediates/mkfs.ubifs.o] Error 1
