udoo> reflow control sheild programing issue? noobish>easy?
Discussion in 'Arduino IDE' started by htsauce, Oct 15, 2014.
  1. htsauce
    htsauce New Member
    Jul 10, 2013
    23
    hey yall thanks for checking in to my issue, any and all comments and insite is appretiated
    i recently bought a reflow control sheild from rocket scream ,
    http://www.rocketscream.com/shop/reflow-oven-controller-shield-arduino-compatible
    came in fast for malaisa,
    code-
    https://github.com/rocketscream/Reflow-Oven-Controller
    i have a preheater and a solder rework station with heat gun , i make a glass enclousuer , do i dont need the toser ovem , im focousing more on direct bga chip reflow, other rework components a plus, but over all that is the main objective , i was planning on useing this as a reflow or profile giude with a thermal coupple,
    so basicly i can watch it and adjust the heat according to the profile , and eventually hook up the ssr to be able to contol the entire prossess or at least the heat gun directly , but i got it as a visual representation of the profile and prossess,
    any who ,
    when i got it , i notice as far as the foot print , there are 2 pins that are un used , the scl and sda and can find them on the provided schmattic but theres no clue as to what they are or there function , on the top two pins on the upper right of the sheild , ,
    im not sure if i need to jump these to another port? or if not needed,
    http://www.rocketscream.com/datashe...erShield/RS-REFLOW-CONTROLLER-SHIELD-1R80.pdf
    any way , my issue is , with the provided code and the librarry files included that they say are required i still get a compileing error and it wont load
    heres my error, im still new to the arduino language so it may be a simple human error issue , but i loaded it in directly , and expect theres may be some modification needed to run udoo or a change of components or librarrys in the code
    the MAX31855.h file is present and is in the direct root of the library folder? im not shure where im goin wron , please and thank you for any and all help and advice :)
    Arduino: 0154 (Linux), Board: "Arduino Due (Programming Port)"
    Using library LiquidCrystal in folder: /opt/arduino-1.5.4/libraries/LiquidCrystal
    /opt/arduino-1.5.4/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -g -Os -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -Dprintf=iprintf -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO=154 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER="Unknown" -DUSB_PRODUCT="Arduino Due" -I/opt/arduino-1.5.4/hardware/arduino/sam/system/libsam -I/opt/arduino-1.5.4/hardware/arduino/sam/system/CMSIS/CMSIS/Include/ -I/opt/arduino-1.5.4/hardware/arduino/sam/system/CMSIS/Device/ATMEL/ -I/opt/arduino-1.5.4/hardware/arduino/sam/cores/arduino -I/opt/arduino-1.5.4/hardware/arduino/sam/variants/arduino_due_x -I/opt/arduino-1.5.4/libraries/LiquidCrystal/src /tmp/build3467053573229346857.tmp/reflowOvenController.cpp -o /tmp/build3467053573229346857.tmp/reflowOvenController.cpp.o
    reflowOvenController.ino:103:23: fatal error: MAX31855.h: No such file or directory
    compilation terminated.
    origonal code
    * Title: Reflow Oven Controller
    * Version: 1.20
    * Date: 26-11-2012
    * Company: Rocket Scream Electronics
    * Author: Lim Phang Moh
    * Website: www.rocketscream.com
    * Brief
    * This is an example firmware for our Arduino compatible reflow oven controller.
    * The reflow curve used in this firmware is meant for lead-free profile
    * (it's even easier for leaded process!). You'll need to use the MAX31855
    * library for Arduino if you are having a shield of v1.60 & above which can be
    * downloaded from our GitHub repository. Please check our wiki
    * (www.rocketscream.com/wiki) for more information on using this piece of code
    * together with the reflow oven controller shield.
    * Temperature (Degree Celcius)                 Magic Happens Here!
    * 245-|                                               x  x
    *     |                                            x        x
    *     |                                         x              x
    *     |                                      x                    x
    * 200-|                                   x                          x
    *     |                              x    |                          |   x
    *     |                         x         |                          |       x
    *     |                    x              |                          |
    * 150-|               x                   |                          |
    *     |             x |                   |                          |
    *     |           x   |                   |                          |
    *     |         x     |                   |                          |
    *     |       x       |                   |                          |
    *     |     x         |                   |                          |
    *     |   x           |                   |                          |
    * 30 -| x             |                   |                          |
    *     |<  60 - 90 s  >|<    90 - 120 s   >|<       90 - 120 s       >|
    *     | Preheat Stage |   Soaking Stage   |       Reflow Stage       | Cool
    *  0  |_ _ _ _ _ _ _ _|_ _ _ _ _ _ _ _ _ _|_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
    *        Time (Seconds)
    * This firmware owed very much on the works of other talented individuals as
    * follows:
    * Brett Beauregard (www.brettbeauregard.com)
    * Author of Arduino PID library. On top of providing industry standard PID
    * implementation, he gave a lot of help in making this reflow oven controller
    * possible using his awesome library.
    * Limor Fried of Adafruit (www.adafruit.com)
    * Author of Arduino MAX6675 library. Adafruit has been the source of tonnes of
    * tutorials, examples, and libraries for everyone to learn.
    * Disclaimer
    * Dealing with high voltage is a very dangerous act! Please make sure you know
    * what you are dealing with and have proper knowledge before hand. Your use of
    * any information or materials on this reflow oven controller is entirely at
    * your own risk, for which we shall not be liable.
    * Licences
    * This reflow oven controller hardware and firmware are released under the
    * Creative Commons Share Alike v3.0 license
    * http://creativecommons.org/licenses/by-sa/3.0/
    * You are free to take this piece of code, use it and modify it.
    * All we ask is attribution including the supporting libraries used in this
    * firmware.
    * Required Libraries
    * - Arduino PID Library:
    *   >> https://github.com/br3ttb/Arduino-PID-Library
    * - MAX31855 Library (for board v1.60 & above):
    *   >> https://github.com/rocketscream/MAX31855
    * - MAX6675 Library (for board v1.50 & below):
    *   >> https://github.com/adafruit/MAX6675-library
    * Revision  Description
    * 1.20			Adds supports for v1.60 (and above) of Reflow Oven Controller
    *           Shield:
    *					  - Uses MAX31855KASA+ chip and pin reassign (allowing A4 & A5 (I2C)
    *             to be used for user application).
    *					  - Uses analog based switch (allowing D2 & D3 to be used for user
    *						  application).
    *						Adds waiting state when temperature too hot to start reflow process.
    *						Corrected thermocouple disconnect error interpretation (MAX6675).
    * 1.10      Arduino IDE 1.0 compatible.
    * 1.00      Initial public release.
    // Comment either one the following #define to select your board revision
    // Newer board version starts from v1.60 using MAX31855KASA+ chip
    #define  USE_MAX31855
    // Older board version below version v1.60 using MAX6675ISA+ chip
    //#define USE_MAX6675
    // ***** INCLUDES *****
    #include <LiquidCrystal.h>
    #ifdef	USE_MAX31855
    	#include <MAX31855.h>
    #else
    	#include <max6675.h>
    #endif
    #include <PID_v1.h>
    // ***** TYPE DEFINITIONS *****
    typedef enum REFLOW_STATE
      REFLOW_STATE_IDLE,
      REFLOW_STATE_PREHEAT,
      REFLOW_STATE_SOAK,
      REFLOW_STATE_REFLOW,
      REFLOW_STATE_COOL,
      REFLOW_STATE_COMPLETE,
    	REFLOW_STATE_TOO_HOT,
      REFLOW_STATE_ERROR
    } reflowState_t;
    typedef enum REFLOW_STATUS
      REFLOW_STATUS_OFF,
      REFLOW_STATUS_ON
    } reflowStatus_t;
    typedef	enum SWITCH
    	SWITCH_NONE,
    	SWITCH_1,
    	SWITCH_2
    }	switch_t;
    typedef enum DEBOUNCE_STATE
      DEBOUNCE_STATE_IDLE,
      DEBOUNCE_STATE_CHECK,
      DEBOUNCE_STATE_RELEASE
    } debounceState_t;
    // ***** CONSTANTS *****
    #define TEMPERATURE_ROOM 50
    #define TEMPERATURE_SOAK_MIN 150
    #define TEMPERATURE_SOAK_MAX 200
    #define TEMPERATURE_REFLOW_MAX 250
    #define TEMPERATURE_COOL_MIN 100
    #define SENSOR_SAMPLING_TIME 1000
    #define SOAK_TEMPERATURE_STEP 5
    #define SOAK_MICRO_PERIOD 9000
    #define DEBOUNCE_PERIOD_MIN 50
    // ***** PID PARAMETERS *****
    // ***** PRE-HEAT STAGE *****
    #define PID_KP_PREHEAT 100
    #define PID_KI_PREHEAT 0.025
    #define PID_KD_PREHEAT 20
    // ***** SOAKING STAGE *****
    #define PID_KP_SOAK 300
    #define PID_KI_SOAK 0.05
    #define PID_KD_SOAK 250
    // ***** REFLOW STAGE *****
    #define PID_KP_REFLOW 300
    #define PID_KI_REFLOW 0.05
    #define PID_KD_REFLOW 350
    #define PID_SAMPLE_TIME 1000
    // ***** LCD MESSAGES *****
    const char* lcdMessagesReflowStatus[] = {
      "Ready",
      "Pre-heat",
      "Soak",
      "Reflow",
      "Cool",
      "Complete",
    	"Wait,hot",
      "Error"
    // ***** DEGREE SYMBOL FOR LCD *****
    unsigned char degree[8]  = {
      140,146,146,140,128,128,128,128};
    // ***** PIN ASSIGNMENT *****
    #ifdef	USE_MAX31855
    	int ssrPin = 5;
    	int thermocoupleSOPin = A3;
    	int thermocoupleCSPin = A2;
    	int thermocoupleCLKPin = A1;
    	int lcdRsPin = 7;
    	int lcdEPin = 8;
    	int lcdD4Pin = 9;
    	int lcdD5Pin = 10;
    	int lcdD6Pin = 11;
    	int lcdD7Pin = 12;
    	int ledRedPin = 4;
    	int buzzerPin = 6;
    	int switchPin = A0;
    #else
    	int ssrPin = 5;
    	int thermocoupleSOPin = A5;
    	int thermocoupleCSPin = A4;
    	int thermocoupleCLKPin = A3;
    	int lcdRsPin = 7;
    	int lcdEPin = 8;
    	int lcdD4Pin = 9;
    	int lcdD5Pin = 10;
    	int lcdD6Pin = 11;
    	int lcdD7Pin = 12;
    	int ledRedPin = A1;
    	int ledGreenPin = A0;
    	int buzzerPin = 6;
    	int switch1Pin = 2;
    	int switch2Pin = 3;
    #endif
    // ***** PID CONTROL VARIABLES *****
    double setpoint;
    double input;
    double output;
    double kp = PID_KP_PREHEAT;
    double ki = PID_KI_PREHEAT;
    double kd = PID_KD_PREHEAT;
    int windowSize;
    unsigned long windowStartTime;
    unsigned long nextCheck;
    unsigned long nextRead;
    unsigned long timerSoak;
    unsigned long buzzerPeriod;
    // Reflow oven controller state machine state variable
    reflowState_t reflowState;
    // Reflow oven controller status
    reflowStatus_t reflowStatus;
    // Switch debounce state machine state variable
    debounceState_t debounceState;
    // Switch debounce timer
    long lastDebounceTime;
    // Switch press status
    switch_t switchStatus;
    // Seconds timer
    int timerSeconds;
    // Specify PID control interface
    PID reflowOvenPID(&input, &output, &setpoint, kp, ki, kd, DIRECT);
    // Specify LCD interface
    LiquidCrystal lcd(lcdRsPin, lcdEPin, lcdD4Pin, lcdD5Pin, lcdD6Pin, lcdD7Pin);
    // Specify MAX6675 thermocouple interface
    #ifdef	USE_MAX31855
    	MAX31855 thermocouple(thermocoupleSOPin, thermocoupleCSPin,
    												thermocoupleCLKPin);
    #else
    	MAX6675 thermocouple(thermocoupleCLKPin, thermocoupleCSPin,
    											 thermocoupleSOPin);
    #endif
    void setup()
      // SSR pin initialization to ensure reflow oven is off
      digitalWrite(ssrPin, LOW);
      pinMode(ssrPin, OUTPUT);
      // Buzzer pin initialization to ensure annoying buzzer is off
      digitalWrite(buzzerPin, LOW);
      pinMode(buzzerPin, OUTPUT);
      // LED pins initialization and turn on upon start-up (active low)
      digitalWrite(ledRedPin, LOW);
      pinMode(ledRedPin, OUTPUT);
    	#ifdef USE_MAX6675
        digitalWrite(ledGreenPin, LOW);
    		pinMode(ledGreenPin, OUTPUT);
    		// Switch pins initialization
    		pinMode(switch1Pin, INPUT);
    		pinMode(switch2Pin, INPUT);
    	#endif
      // Start-up splash
      digitalWrite(buzzerPin, HIGH);
      lcd.begin(8, 2);
      lcd.createChar(0, degree);
      lcd.clear();
      lcd.print("Reflow");
      lcd.setCursor(0, 1);
      lcd.print("Oven 1.2");
      delay(2500);
      lcd.clear();
      // Serial communication at 57600 bps
      Serial.begin(57600);
      // Turn off LED (active low)
      digitalWrite(ledRedPin, HIGH);
    	#ifdef  USE_MAX6675
    		digitalWrite(ledGreenPin, HIGH);
    	#endif
      // Set window size
      windowSize = 2000;
      // Initialize time keeping variable
      nextCheck = millis();
      // Initialize thermocouple reading variable
      nextRead = millis();
    void loop()
      // Current time
      unsigned long now;
      // Time to read thermocouple?
      if (millis() > nextRead)
        // Read thermocouple next sampling period
        nextRead += SENSOR_SAMPLING_TIME;
        // Read current temperature
    		#ifdef	USE_MAX31855
    			input = thermocouple.readThermocouple(CELSIUS);
    		#else
    			input = thermocouple.readCelsius();
    		#endif
        // If thermocouple problem detected
    		#ifdef	USE_MAX6675
    			if (isnan(input))
    		#else
    			if((input == FAULT_OPEN) || (input == FAULT_SHORT_GND) ||
    				 (input == FAULT_SHORT_VCC))
        #endif
          // Illegal operation
          reflowState = REFLOW_STATE_ERROR;
          reflowStatus = REFLOW_STATUS_OFF;
      if (millis() > nextCheck)
        // Check input in the next seconds
        nextCheck += 1000;
        // If reflow process is on going
        if (reflowStatus == REFLOW_STATUS_ON)
          // Toggle red LED as system heart beat
          digitalWrite(ledRedPin, !(digitalRead(ledRedPin)));
          // Increase seconds timer for reflow curve analysis
          timerSeconds++;
          // Send temperature and time stamp to serial
          Serial.print(timerSeconds);
          Serial.print(" ");
          Serial.print(setpoint);
          Serial.print(" ");
          Serial.print(input);
          Serial.print(" ");
          Serial.println(output);
        else
          // Turn off red LED
        // Clear LCD
        lcd.clear();
        // Print current system state
        lcd.print(lcdMessagesReflowStatus[reflowState]);
        // Move the cursor to the 2 line
        // If currently in error state
        if (reflowState == REFLOW_STATE_ERROR)
          // No thermocouple wire connected
          lcd.print("TC Error!");
        else
          // Print current temperature
          lcd.print(input);
    			#if ARDUINO >= 100
    				// Print degree Celsius symbol
    				lcd.write((uint8_t)0);
    			#else
    				lcd.print(0, BYTE);
    			#endif
          lcd.print("C ");
      switch (reflowState)
      case REFLOW_STATE_IDLE:
    		// If oven temperature is still above room temperature
    		if (input >= TEMPERATURE_ROOM)
    			reflowState = REFLOW_STATE_TOO_HOT;
    		else
    			// If switch is pressed to start reflow process
    			if (switchStatus == SWITCH_1)
            // Send header for CSV file
            Serial.println("Time Setpoint Input Output");
            // Intialize seconds timer for serial debug information
            timerSeconds = 0;
            // Initialize PID control window starting time
            windowStartTime = millis();
            // Ramp up to minimum soaking temperature
            setpoint = TEMPERATURE_SOAK_MIN;
            // Tell the PID to range between 0 and the full window size
            reflowOvenPID.SetOutputLimits(0, windowSize);
            reflowOvenPID.SetSampleTime(PID_SAMPLE_TIME);
            // Turn the PID on
            reflowOvenPID.SetMode(AUTOMATIC);
            // Proceed to preheat stage
            reflowState = REFLOW_STATE_PREHEAT;
        break;
      case REFLOW_STATE_PREHEAT:
        reflowStatus = REFLOW_STATUS_ON;
        // If minimum soak temperature is achieve
        if (input >= TEMPERATURE_SOAK_MIN)
          // Chop soaking period into smaller sub-period
          timerSoak = millis() + SOAK_MICRO_PERIOD;
          // Set less agressive PID parameters for soaking ramp
          reflowOvenPID.SetTunings(PID_KP_SOAK, PID_KI_SOAK, PID_KD_SOAK);
          // Ramp up to first section of soaking temperature
          setpoint = TEMPERATURE_SOAK_MIN + SOAK_TEMPERATURE_STEP;
          // Proceed to soaking state
          reflowState = REFLOW_STATE_SOAK;
        break;
      case REFLOW_STATE_SOAK:
        // If micro soak temperature is achieved
        if (millis() > timerSoak)
          // Increment micro setpoint
          setpoint += SOAK_TEMPERATURE_STEP;
          if (setpoint > TEMPERATURE_SOAK_MAX)
            // Set agressive PID parameters for reflow ramp
            reflowOvenPID.SetTunings(PID_KP_REFLOW, PID_KI_REFLOW, PID_KD_REFLOW);
            setpoint = TEMPERATURE_REFLOW_MAX;
            // Proceed to reflowing state
            reflowState = REFLOW_STATE_REFLOW;
        break;
      case REFLOW_STATE_REFLOW:
        // We need to avoid hovering at peak temperature for too long
        // Crude method that works like a charm and safe for the components
        if (input >= (TEMPERATURE_REFLOW_MAX - 5))
          // Set PID parameters for cooling ramp
          // Ramp down to minimum cooling temperature
          setpoint = TEMPERATURE_COOL_MIN;
          // Proceed to cooling state
          reflowState = REFLOW_STATE_COOL;
        break;
      case REFLOW_STATE_COOL:
        // If minimum cool temperature is achieve
        if (input <= TEMPERATURE_COOL_MIN)
          // Retrieve current time for buzzer usage
          buzzerPeriod = millis() + 1000;
          // Turn on buzzer and green LED to indicate completion
    			#ifdef	USE_MAX6675
          #endif
          // Turn off reflow process
          // Proceed to reflow Completion state
          reflowState = REFLOW_STATE_COMPLETE;
        break;
      case REFLOW_STATE_COMPLETE:
        if (millis() > buzzerPeriod)
          // Turn off buzzer and green LED
    			#ifdef	USE_MAX6675
    			#endif
    			// Reflow process ended
          reflowState = REFLOW_STATE_IDLE;
        break;
    	case REFLOW_STATE_TOO_HOT:
    		// If oven temperature drops below room temperature
    		if (input < TEMPERATURE_ROOM)
    			// Ready to reflow
    		break;
      case REFLOW_STATE_ERROR:
        // If thermocouple problem is still present
    		#ifdef	USE_MAX6675
    			if (isnan(input))
    		#else
        #endif
          // Wait until thermocouple wire is connected
        else
          // Clear to perform reflow process
        break;
      // If switch 1 is pressed
        // If currently reflow process is on going
          // Button press is for cancelling
          // Reinitialize state machine
      // Simple switch debounce state machine (for switch #1 (both analog & digital
    	// switch supported))
      switch (debounceState)
      case DEBOUNCE_STATE_IDLE:
        // No valid switch press
        switchStatus = SWITCH_NONE;
        // If switch #1 is pressed
    		#ifdef	USE_MAX6675
    			if (digitalRead(switch1Pin) == LOW)
    		#else
    			if (analogRead(switchPin) == 0)
    		#endif
    				// Intialize debounce counter
    				lastDebounceTime = millis();
    				// Proceed to check validity of button press
    				debounceState = DEBOUNCE_STATE_CHECK;
        break;
      case DEBOUNCE_STATE_CHECK:
    		#ifdef	USE_MAX6675
    			// If switch #1 is still pressed
    		#else
    		#endif
    				// If minimum debounce period is completed
    				if ((millis() - lastDebounceTime) > DEBOUNCE_PERIOD_MIN)
    					// Proceed to wait for button release
    					debounceState = DEBOUNCE_STATE_RELEASE;
    			// False trigger
    			else
    				// Reinitialize button debounce state machine
    				debounceState = DEBOUNCE_STATE_IDLE;
        break;
      case DEBOUNCE_STATE_RELEASE:
    		#ifdef	USE_MAX6675
    			if (digitalRead(switch1Pin) == HIGH)
        #else
    			if (analogRead(switchPin) > 0)
    		#endif
          // Valid switch 1 press
          switchStatus = SWITCH_1;
        break;
      // PID computation and SSR control
        now = millis();
        reflowOvenPID.Compute();
        if((now - windowStartTime) > windowSize)
          // Time to shift the Relay Window
          windowStartTime += windowSize;
        if(output > (now - windowStartTime)) digitalWrite(ssrPin, HIGH);
        else digitalWrite(ssrPin, LOW);
      // Reflow oven process is off, ensure oven is off
      else
    verry much
  2. htsauce
    htsauce New Member
    Jul 10, 2013
    23
    Re: udoo> reflow control sheild programing issue? noobish>e
    yelp!!!!!????????????
