Udoo won't boot, solid green light.
Discussion in 'Troubleshooting' started by orangeribbon, Jul 19, 2014.
  1. orangeribbon
    orangeribbon New Member
    Jan 1, 2014
    I tend to leave my udoo on most of the time, but I had to take it down and bring it into work. Now it won't boot.
    When I try to connect to the com port via putty (I am on win 7) I get no information at all when connected to the PC.
    I have tried new cards (that I know work) and tried two different HDMI cords that I know work.
    Did I fry it?
  2. peter247
    peter247 Member
    Mar 10, 2014
    263
    The jumper near J1 is in place right ?.
    correct baud rate and coms port ?.
    check your psu for voltage drop ?
    After that no idea , but sound bad !!!!! , it could be the sd socket / pins.
  3. delba
    1,064
    The only way to see if UDOO works is to connect it via serial cable. If putty doesn't show anything this probably means that UDOO is fried or that you just didn't configure putty in the right way. Please be sure to follow the "Connecting via Serial from Windows" section of this tutorial: http://www.udoo.org/ProjectsAndTutorial ... lioID=1394
  4. orangeribbon
    Jan 1, 2014
    I checked the jumpers, I have J18 and J16 on and that is the tutorial I fallowed. When I looked up the com port in Device Manager the baud rate was different so I tried both.
    Sad I really enjoyed my Udoo.
