UDOO-X86 Android Not Seeing Wifi/Bluetooth Module
Discussion in 'UDOO X86' started by Doug Walmsley, May 4, 2017.
  1. Doug Walmsley
    Doug Walmsley UDOOer
    May 4, 2017
    Has any been able to get their new X86 board with Wifi/Bluetooth module to work with android-x86_64-6.0-r3 OS? I know the module works with Ubuntu and Window 10 but no luck with Android.
    B Tung likes this.
  2. Guiz
    Guiz New Member
    Apr 30, 2017
    I faced the same issue.
    Another problem is the screen orientation... I installed an app which runs only in portait but my desktop screen doesn't turn :(
    Does anyone know how to turn back the screen in landscape mode ?
  3. waltervl
    There is a gyroscope/accelerometer on board so I would suggest to turn the Udoo X86 and it will flip the screen.
    Just kidding... :)
    Isn't there a Android X86 forum out there? This has nothing to do with Udoo hardware. Other people running Android on PC hardware should have the same issues I suppose.
  4. Doug Walmsley
    May 4, 2017
    @Guiz,
    I don't seem to have the same issue. My 24 inch HDMI monitor is in landscape orientation and when I installed OS' the desktop came up in Landscape.
  5. zanteh
    zanteh New Member
    Mar 10, 2017
    Same here. Wifi module not working
  6. waltervl
    Alexander Chang likes this.
  7. Jon West
    Jon West New Member
    Jun 27, 2017
    I would like to get a few testers for some Udoo-x86 specific builds of Bliss-x86. I'm still getting used to this form of development with hardware combinations that aren't too widely supported, but I've come a long way recently, and working together, we could possibly get it all working right for the Udoo-x86.
    Message me or find me on Google ;)
  8. stecolumna
    stecolumna UDOOer
    May 20, 2016
    158
    38
    Dear waltervl
    I tried installing in the internal 32GB EMMC Bliss Android bliss_android_x86_64 from USB key in legacy boot mode and it install but did not boot (single white line and black screen). Must I start from EFI? In legacy I tried either to install the Bliss Android GRUB and not to install it and to run the update-grub of Debian 9.0.1 installed on M2 disk but hoping to use it but does not recognize the Bliss Android installation. In Debian 9.0.1 installed in the M2 disk I can mount correctly the internal 32GB EMMC and look the files installed by Bliss Android but I can't boot it.
    Thanks in advance.
  9. waltervl
    I personally have no experience with Android on Udoo X86 (nor plans to get involved, 1 OS is enough for me).
    Perhaps @Jon West could answer your question as he is involved in the development of Bliss-X86
  10. stecolumna
    stecolumna UDOOer
    May 20, 2016
    158
    38
    Dear waltervl thanks for your answer. Please I want to know from @Jon West if I have to "Create a small (100m) first primary partition for grub" according to this suggestions (https://unix.stackexchange.com/ques...g-android-x86-only-tgrub-showing-when-booting), or, in alternative, modify the Debian 9.0.1 (on M2) "my 40_Costum" file to obtain a menu entry for Android in Debian GRUB. However I prefer a separate GRUB installed in the same physical memory unit where is installed the OS.
    I have to add that in Udoox86 Ultra internal EMMC 32GB I have this hardware device: mmcblk0boot0 and mmcblk0boot1 and mmcblk0rpmb
    root@amatronico:/home/stecolumna# lsblk
    NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
    sda 8:0 0 477G 0 disk
    ├─sda1 8:1 0 469G 0 part /
    ├─sda2 8:2 0 1K 0 part
    └─sda5 8:5 0 7,9G 0 part [SWAP]
    sdb 8:16 1 7,5G 0 disk
    ├─sdb1 8:17 1 801M 0 part
    └─sdb2 8:18 1 3M 0 part
    mmcblk0 179:0 0 29,1G 0 disk
    └─mmcblk0p1 179:1 0 29,1G 0 part
    mmcblk0boot0 179:256 0 4M 1 disk
    mmcblk0boot1 179:512 0 4M 1 disk
    mmcblk0rpmb 179:768 0 4M 0 disk
    mmcblk1 179:1024 0 59,5G 0 disk
    ├─mmcblk1p1 179:1025 0 51,2G 0 part
    ├─mmcblk1p2 179:1026 0 1K 0 part
    └─mmcblk1p5 179:1029 0 8,3G 0 part
    Thanks to all
  11. Jon West
    Jon West New Member
    Jun 27, 2017
    This is where I feel the problem might be for now. I think Android-x86 kernels don't have the needed commits to boot properly from the emmc, but I am looking into that part currently. The latest builds we have on the bliss downloads site for the udoo do have all the needed EFS bits to install and boot properly from the SSD though, so that is where I have my test builds installing to.
  12. stecolumna
    stecolumna UDOOer
    May 20, 2016
    158
    38
    Dear Jon West
    I thank your for your answer and I want only add that after the installation of bliss_android_x86_64 I have also tried the "lunch Android" option and effectively it started the OS logo but in a loop, i.e. always and only the logo.
  13. Jon West
    Jon West New Member
    Jun 27, 2017
    Not too sure you installed it using the latest .img from our website. Or if you installed the one the Udoo devs built. Either way, the first boot will show the bootanimation for a good 10 minutes potentially.
  14. stecolumna
    stecolumna UDOOer
    May 20, 2016
    158
    38
    I have used android-x86_64-6.0-r3.iso
    [correction =]
    Bliss-v7.2-android_x86_64-UNOFFICIAL-20170615-1518.iso
    Thanks again
  15. stecolumna
    stecolumna UDOOer
    May 20, 2016
    158
    38
    Dear Jon West
    Thanks to your observation about the fact that the logo can stay up to 10 minutes I have reinstalled and I launched Android before to exit and waited and finally the system started on.
    Android recognized two monitors and saw the available wifi networks. So it seems to recognize the wifi usb dongle.
    The problems are
    1) that UI system blocked but I used ALT+F1 to obtain the shell and I used the command reboot
    2) the reboot failed to launch the SO perhaps for the GRUB problem discussed in the precedent posts
    Now I will do more tests.
    Thank you
