Udoo x86 Android + Webcams/USB Cameras
Discussion in 'UDOO X86' started by ChinhNK, Feb 21, 2018.
Tags:
  1. ChinhNK
    ChinhNK New Member
    Feb 21, 2018
    I want to try out Google Mobile Vision functionalities so I installed BlissOS on my Udoo x86. Is there a way to mount my Logitech webcam (B525) to the Udoo and use it with Android CameraAPI ?
    I tried to plug it in and got this on adb:
    02-21 13:04:55.897  1234  1234 E V4L2Camera: ERROR opening V4L interface /dev/video0: No such file or directory
    02-21 13:04:55.897  1234  1234 E CameraHardware: Failed to initialize Camera
    02-21 13:04:55.899 13609 13655 E RequestThread-0: Received device exception during capture call:
    02-21 13:04:55.899 13609 13655 E RequestThread-0: java.lang.RuntimeException: startPreview failed
    02-21 13:04:55.899 13609 13655 E RequestThread-0:     at android.hardware.Camera.startPreview(Native Method)
    02-21 13:04:55.899 13609 13655 E RequestThread-0:     at android.hardware.camera2.legacy.RequestThreadManager.startPreview(RequestThreadManager.java:288)
    02-21 13:04:55.899 13609 13655 E RequestThread-0:     at android.hardware.camera2.legacy.RequestThreadManager.doPreviewCapture(RequestThreadManager.java:330)
    02-21 13:04:55.899 13609 13655 E RequestThread-0:     at android.hardware.camera2.legacy.RequestThreadManager.-wrap3(RequestThreadManager.java)
    02-21 13:04:55.899 13609 13655 E RequestThread-0:     at android.hardware.camera2.legacy.RequestThreadManager$5.handleMessage(RequestThreadManager.java:815)
    02-21 13:04:55.899 13609 13655 E RequestThread-0:     at android.os.Handler.dispatchMessage(Handler.java:98)
    02-21 13:04:55.899 13609 13655 E RequestThread-0:     at android.os.Looper.loop(Looper.java:154)
    02-21 13:04:55.899 13609 13655 E RequestThread-0:     at android.os.HandlerThread.run(HandlerThread.java:61)
    02-21 13:04:55.902  1234  1234 E V4L2Camera: ERROR opening V4L interface /dev/video0: No such file or directory
    02-21 13:04:55.902  1234  1234 E CameraHardware: Failed to initialize Camera
    02-21 13:04:55.903 13609 13640 E CAM_FatalErrorHandler: Handling Camera Access Failure:
    02-21 13:04:55.903 13609 13640 E CAM_FatalErrorHandler: java.lang.Exception
    02-21 13:04:55.903 13609 13640 E CAM_FatalErrorHandler:     at com.android.camera.FatalErrorHandlerImpl.onGenericCameraAccessFailure(FatalErrorHandlerImpl.java:84)
    02-21 13:04:55.903 13609 13640 E CAM_FatalErrorHandler:     at com.android.camera.one.v2.Camera2OneCameraOpenerImpl$1.onError(Camera2OneCameraOpenerImpl.java:154)
    02-21 13:04:55.903 13609 13640 E CAM_FatalErrorHandler:     at android.hardware.camera2.impl.CameraDeviceImpl$CameraDeviceCallbacks$1.run(CameraDeviceImpl.java:1684)
    02-21 13:04:55.903 13609 13640 E CAM_FatalErrorHandler:     at android.os.Handler.handleCallback(Handler.java:751)
    02-21 13:04:55.903 13609 13640 E CAM_FatalErrorHandler:     at android.os.Handler.dispatchMessage(Handler.java:95)
    02-21 13:04:55.903 13609 13640 E CAM_FatalErrorHandler:     at android.os.Looper.loop(Looper.java:154)
    02-21 13:04:55.903 13609 13640 E CAM_FatalErrorHandler:     at android.os.HandlerThread.run(HandlerThread.java:61)
    02-21 13:04:55.904 13609 13655 E RequestThread-0: Received device exception during capture call:
    02-21 13:04:55.904 13609 13655 E RequestThread-0: java.lang.RuntimeException: startPreview failed
    02-21 13:04:55.904 13609 13655 E RequestThread-0:     at android.hardware.Camera.startPreview(Native Method)
    02-21 13:04:55.904 13609 13655 E RequestThread-0:     at android.hardware.camera2.legacy.RequestThreadManager.startPreview(RequestThreadManager.java:288)
    02-21 13:04:55.904 13609 13655 E RequestThread-0:     at android.hardware.camera2.legacy.RequestThreadManager.doPreviewCapture(RequestThreadManager.java:330)
    02-21 13:04:55.904 13609 13655 E RequestThread-0:     at android.hardware.camera2.legacy.RequestThreadManager.-wrap3(RequestThreadManager.java)
    02-21 13:04:55.904 13609 13655 E RequestThread-0:     at android.hardware.camera2.legacy.RequestThreadManager$5.handleMessage(RequestThreadManager.java:815)
    02-21 13:04:55.904 13609 13655 E RequestThread-0:     at android.os.Handler.dispatchMessage(Handler.java:98)
    02-21 13:04:55.904 13609 13655 E RequestThread-0:     at android.os.Looper.loop(Looper.java:154)
    02-21 13:04:55.904 13609 13655 E RequestThread-0:     at android.os.HandlerThread.run(HandlerThread.java:61)
    Helps are much appreciated.
    BR.
  2. ccs_hello
    536
    194
    Logitech B525 is a UVC webcam.
    Many Linux distributions have UVC built-into the kernel driver as UVC is the most basic type,
    Not sure your Android-x86 has it or not.
    LDighera likes this.
