UDOO X86 available for direct purchase
Discussion in 'UDOO X86' started by Laura, Jul 3, 2017.
  1. samholton
    samholton New Member
    May 22, 2017
    26
    The original thread discussing this --> https://www.udoo.org/forum/threads/ultra-in-what-situation-should-it-boost-up-to-2-56ghz.6989/
    I have the advanced running Debian Stretch.
    root@udoo:~# cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors
    performance powersave
    I only see two available governors. Powersave was selected by default.
    Powersave
    analyzing CPU 3:
      driver: intel_pstate
      CPUs which run at the same hardware frequency: 3
      CPUs which need to have their frequency coordinated by software: 3
      maximum transition latency: 0.97 ms.
      hardware limits: 480 MHz - 2.24 GHz
      available cpufreq governors: performance, powersave
      current policy: frequency should be within 480 MHz and 1.79 GHz.
                      The governor "powersave" may decide which speed to use
                      within this range.
      current CPU frequency is 480 MHz (asserted by call to hardware).
    Performance
    analyzing CPU 3:
                      The governor "performance" may decide which speed to use
                      within this range.
      current CPU frequency is 788 MHz (asserted by call to hardware).
    I haven't looked into it much. But with either one selected I seem to cap out at 1.76 GHz. The hardware limit clearly shows 2.24 GHz but the two only available governors only go up to 1.79 GHz
  2. Markus Laire
    Markus Laire Active Member
    Mar 9, 2017
    225
    92
    For some reason speed is limited to 80% of maximum. 1.79 GHz is 80% of 2.24 GHz, and on my Ultra also 2.05 GHz is 80% of 2.56 GHz.
  3. Robert Pearson
    Robert Pearson Member
    36
    15
    Here's a screen shot of my Udoo X86 Ultra, with the CPU clock at 2.55GHz. The hardware is capable of the burst speeds to 2.55GHz with Windows 10. Windows 10 has great control over usage of the burst speeds. It will even burst to 2.55GHz at 50% utilization.
    I did some playing with Ubuntu and Debian, and they both set governed speeds less than the capable speed. "cpufreq-set -u 2560000" is literally ignored by the pstate driver. The pstate driver appears to be stuck in the early days of thought where you didnt have a good understanding of the CPU capabilities, and is conservative in settings for stability reasons. There's instructions in the internet for turning off pstate drivers, and control it natively. With the lack of *GOOD* BIOS control for the CPU fan, I would hesitate to do this myself, as I would choose a cooler / more stable system.
    Linux is great for many things, but not for decent control over a processor it seems. Video adapters had similar problems with drivers for years. You should work with the Linux community for a resolution as the Udoo hardware appears to be working as designed.
    Robert
    Markus Laire likes this.
  4. Robert Pearson
    36
    15
    for those wondering... "The impossible is completely different output. Can you share screenshots?"
  5. jesse coppens
    jesse coppens New Member
    Aug 2, 2017
    i was wondering i ordered the x86 ultra with other things when will it be delivered i am from the Netherlands how many days ?
  6. Laura
    Laura UDOOer
    Apr 22, 2016
    374
    156
    Sorry for the delayed response @jesse coppens. Orders from the UDOO Shop are usually processed withing 3-days, and shipped using an express service from UPS with a 1-5 working day delivery commitment.
    Orders placed between the 4th and 21st August, will be shipped from the 23rd August.
  7. PeterRobinson
    PeterRobinson New Member
    Feb 23, 2017
    14
    Hopefully I will be getting the ultra for Christmas!
  8. Ibsen
    Ibsen New Member
    Jan 15, 2018
    I don't see the Check Out button to order the x86 Ultra ???
  9. Ibsen
    Ibsen New Member
    Jan 15, 2018
    I meant to say "Add to Cart" ???
  10. Laura
    Laura UDOOer
    Apr 22, 2016
    374
    156
    The UDOO X86 ULTRA is back in stock now and can be added to the cart.
  11. Alicia Billings
    Alicia Billings New Member
    Jan 4, 2018
    Hi Laura,
    Do you know when the x86 advanced plus will be back in stock?
  12. Laura
    Laura UDOOer
    Apr 22, 2016
    374
    156
    Hi @Alicia Billings. The UDOO X86 ADVANCED PLUS is now back in stock. Thank you for your interest!
  13. leonardo.cortes
    leonardo.cortes New Member
    Mar 19, 2018
    Mmmm good platform for linux and voip services.....
  14. Nozavi
    Nozavi New Member
    Apr 14, 2018
    Any ETA on when it will be back on stock? :)
    Thank you!
  15. Laura
    Laura UDOOer
    Apr 22, 2016
    374
    156
  16. Nozavi
    Nozavi New Member
    Apr 14, 2018
    Awesome, thank you! Is there any chance of seeing the case and power supply back in stock too? I'd like to purchase them all in one go if possible ;)
