UDOO x86 Ultra issue with Ethernet Adapter.
Discussion in 'UDOO X86' started by Elochukwu Oku, Oct 6, 2020.
  1. Elochukwu Oku
    Elochukwu Oku UDOOer
    Jul 9, 2019
    10
    Today, I turned on PC and noticed Ethernet adapter not detected, Had to check and found out some
    component is already off the board may be due to heat and I also noticed my Fan do not work acording to bios settings.
    I want to know if its really these componenets the cause and how to solder it back:).
    [​IMG]
    [​IMG]
    I am not a Tech guru. these tiny componenets are still new to me. It looks like a resistor though. Lucky I found theem glued around the metal case inside. I checked the Board pictures and I think I found where they pulled out from near the ethenet port.
    [​IMG]
    Not surer I can be able to solder this. Its too tiny.
    Final question, Can the PC still work without it by using USB Ethernet adapter? Is it risky. So curious because I dont have money for new board and a bit fraustrated due to project I am using it for.
    I do not see any images.
    But normally the pc can work without ethernet. You better worry why components are falling of your board....
