Udoobuntu 2.2.0 missing ipv6 iptables
Discussion in 'Linux Ubuntu' started by fireblade, Jan 27, 2018.
  1. fireblade
    fireblade UDOOer
    16
    was trying to configure ufw on a UdooNeo running UDOObuntu 2.2.0
     sudo ufw allow to any app openssh
    and got
    ERROR: initcaps
    [Errno 2] modprobe: FATAL: Module ip6_tables not found.
    ip6tables v1.4.21: can't initialize ip6tables table `filter': No chain/target/match by that name
    Perhaps ip6tables or your kernel needs to be upgraded.
    so tried
    sudo ip6tables -L
    and got
    which to me looks like the kernel module(s) for ipv6 iptables is missing
    im not familiar with recompiling the kernel so can anyone tell me what i have to do to fix this?
    also im not sure how wise it it to have ipv6 support without support for an ipv6 capable firewall
    edit 1
    have found https://www.udoo.org/docs-neo/Advanced_Topics/Compile_Linux_Kernel.html
    however gcc-arm-linux-gnueabihf appears available from udoobuntu default repositories
    Package gcc-arm-linux-gnueabihf is not available, but is referred to by another package.
    This may mean that the package is missing, has been obsoleted, or
    is only available from another source
    E: Package 'gcc-arm-linux-gnueabihf' has no installation candidate
  2. igorpec
    igorpec UDOOer
    Jan 25, 2015
    26
    Perhaps you could try Armbian. Building kernel or image is super easy - you only need to setup Ubuntu Xenial X64 virtual machine, run on it or under Docker ... https://github.com/armbian/build does everything for you.
  3. fireblade
    fireblade UDOOer
    16
    using ubuntu and those instructions successfully compiled the kernel (might try armbian in future) using a vm with ubuntu 16.04 LTS
    need to use
    ARCH=arm make menuconfig
    to add correct modules
    found tool for ufw to test for right modules /usr/share/ufw/check-requirements
    and now appear to have a functional configuration where ufw enables and allows OpenSSH
    have attached .config file for anyone interested
