UDOOBuntu Quad Boot Issues
Discussion in 'Troubleshooting' started by humblehacker, Aug 21, 2014.
  1. humblehacker
    humblehacker New Member
    Apr 7, 2014
    16
    Hello,
    I've been experiencing issues booting the new UDOOBuntu OS for a Quad board. When I plug it in it immediately flashes a system info screen that displays the UDOO logo and basic system info like " CPU: Freescale i.MX6Q rev1.2 at 792 MHz".
    After about 3 seconds it reverts to a black screen and remains black no matter how long I wait.
    The debug output doesn't seem to match anything on the http://www.udoo.org/faq-items/why-my-udoo-wont-boot/ page. The culprit seems to be the line-
    which seems to imply a data corruption. I repeatedly checked the hash to confirm the files integrity though I should mention that downloads from sourceforge and the direct link were flagged as corrupt on two different MAC machines and two different Linux for which one download even caused a kernel panic!
    Reset cause: POR
    Board: UDOO
    DRAM:  1 GiB
    MMC:   FSL_SDHC: 0
    No panel detected: default to LDB-WVGA
    Display: LDB-WVGA (800x480)
    In:    serial
    Out:   serial
    Err:   serial
    Net:   using phy at 6
    FEC [PRIME]
    AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
    flags: ncq stag pm led clo only pmp pio slum part
    No port device detected!
    sata - SATA sub system
    Usage:
    sata init - init SATA sub system
    sata info - show available SATA devices
    sata device [dev] - show or set current device
    sata part [dev] - print partition table
    sata read addr blk# cnt
    sata write addr blk# cnt
    Usage:
    Booting from mmc ...
    4788388 bytes read in 364 ms (12.5 MiB/s)
    ## Booting kernel from Legacy Image at 12000000 ...
       Image Name:   Linux-3.0.35
       Data Size:    4788324 Bytes = 4.6 MiB
       Load Address: 10008000
       Entry Point:  10008000
       Verifying Checksum ... OK
       Loading Kernel Image ... OK
    Starting kernel ...
    [    0.000000] Initializing cgroup subsys cpu
    [    0.000000] Linux version 3.0.35 (udoo@ubuntu) (gcc version 4.4.4 (4.4.4_09.0
    6.2010) ) #7 SMP PREEMPT Thu Jul 3 15:12:59 CEST 2014
    [    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] Machine: SECO i.Mx6 UDOO Board
    [    0.000000] Kernel ver: v. 131\nMemory policy: ECC disabled, Data cache write
    alloc
    [    0.000000] CPU identified as i.MX6Q, silicon rev 1.2
    [    0.000000] PERCPU: Embedded 7 pages/cpu @8c008000 s5504 r8192 d14976 u32768
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pag
    es: 227328
    [    0.000000] Kernel command line: console=ttymxc1,115200 root=/dev/mmcblk0p1 r
    ootwait rw fbmem=24M gpu_reserved=128M video=mxcfb0:dev=hdmi,1920x1080M@60,bpp=3
    [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Memory: 640MB 256MB = 896MB total
    [    0.000000] Memory: 895020k/895020k available, 153556k reserved, 0K highmem
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    [    0.000000]     DMA     : 0xf4600000 - 0xffe00000   ( 184 MB)
    [    0.000000]     vmalloc : 0xc0800000 - 0xf2000000   ( 792 MB)
    [    0.000000]     lowmem  : 0x80000000 - 0xc0000000   (1024 MB)
    [    0.000000]     pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    [    0.000000]     modules : 0x7f000000 - 0x7fe00000   (  14 MB)
    [    0.000000]       .init : 0x80008000 - 0x8003a000   ( 200 kB)
    [    0.000000]       .text : 0x8003a000 - 0x80c474f0   (12342 kB)
    [    0.000000]       .data : 0x80c48000 - 0x80cb4c80   ( 436 kB)
    [    0.000000]        .bss : 0x80cb4ca4 - 0x80d077e4   ( 331 kB)
    [    0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, N
    odes=1
    [    0.000000] Preemptible hierarchical RCU implementation.
    [    0.000000] NR_IRQS:624
    [    0.000000] MXC GPIO hardware
    [    0.000000] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 14
    31655ms
    [    0.000000] arm_max_freq=1GHz
    [    0.000000] MXC_Early serial console at MMIO 0x21e8000 (options '115200')
    [    0.000000] bootconsole [ttymxc1] enabled
    [    0.000000] Console: colour dummy device 80x30
    [    0.219502] Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
    [    0.307839] pid_max: default: 32768 minimum: 301
    [    0.312724] Mount-cache hash table entries: 512
    [    0.317970] Initializing cgroup subsys cpuacct
    [    0.322471] Initializing cgroup subsys devices
    [    0.326930] Initializing cgroup subsys freezer
    [    0.331421] Initializing cgroup subsys blkio
    [    0.335759] CPU: Testing write buffer coherency: ok
    [    0.340915] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counter
    s available
    [    0.441445] CPU1: Booted secondary processor
    [    0.521446] CPU2: Booted secondary processor
    [    0.601467] CPU3: Booted secondary processor
    [    0.640951] Brought up 4 CPUs
    [    0.656778] SMP: Total of 4 processors activated (6324.22 BogoMIPS).
    [    0.663578] devtmpfs: initialized
    [    0.683844] print_constraints: dummy:
    [    0.687837] NET: Registered protocol family 16
    [    0.696721] print_constraints: vddpu: 725 <--> 1300 mV at 1150 mV fast normal
    [    0.704303] print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast norm
    al
    [    0.712076] print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast norma
    l
    [    0.719716] print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast norm
    al
    [    0.727490] print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast norma
    l
    [    0.735173] print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast norm
    al
    [    0.744264]
    [    0.744270] > UDOO quad
    [    0.748043] > rev C Called set_gpios_direction
    [    0.752721] Test and set gpios directions and values by Gionji feat. Ekirei t
    est
    [    0.784532] Resetting ethernet physical layer.
    [    0.827768] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
    [    0.834604] hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-ste
    p.
    [    0.841964] hw-breakpoint: maximum watchpoint size is 4 bytes.
    [    0.847851] L310 cache controller enabled
    [    0.851894] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x02070000, Cache si
    ze: 1048576 B
    [    0.902376] bio: create slab <bio-0> at 0
    [    0.909837] mxs-dma mxs-dma-apbh: initialized
    [    0.914559] print_constraints: vmmc: 3300 mV
    [    0.919675] vgaarb: loaded
    [    0.923247] SCSI subsystem initialized
    [    0.928142] usbcore: registered new interface driver usbfs
    [    0.933801] usbcore: registered new interface driver hub
    [    0.939306] usbcore: registered new device driver usb
    [    0.944387] Freescale USB OTG Driver loaded, $Revision: 1.55 $
    [    0.970950] imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(
    6,7)
    [    0.990944] imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(
    6,7)
    [    0.998774] mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed
    [    1.005256] mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x313
    0302a
    [    1.012980] MIPI CSI2 driver module loaded
    [    1.017345] Advanced Linux Sound Architecture Driver Version 1.0.24.
    [    1.024559] Bluetooth: Core ver 2.16
    [    1.028271] NET: Registered protocol family 31
    [    1.032740] Bluetooth: HCI device and connection manager initialized
    [    1.039116] Bluetooth: HCI socket layer initialized
    [    1.044018] Bluetooth: L2CAP socket layer initialized
    [    1.049149] Bluetooth: SCO socket layer initialized
    [    1.054508] cfg80211: Calling CRDA to update world regulatory domain
    [    1.061948] i2c-core: driver [max17135] using legacy suspend method
    [    1.068236] i2c-core: driver [max17135] using legacy resume method
    [    1.074464] Switching to clocksource mxc_timer1
    [    1.094521] NET: Registered protocol family 2
    [    1.099107] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
    [    1.107019] TCP established hash table entries: 131072 (order: 8, 1048576 byt
    es)
    [    1.116357] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
    [    1.124094] TCP: Hash tables configured (established 131072 bind 65536)
    [    1.130743] TCP reno registered
    [    1.133903] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    1.139885] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    1.146616] NET: Registered protocol family 1
    [    1.151294] RPC: Registered named UNIX socket transport module.
    [    1.157234] RPC: Registered udp transport module.
    [    1.161971] RPC: Registered tcp transport module.
    [    1.166690] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.174067] PMU: registered new PMU device of type 0
    [    1.179204] Static Power Management for Freescale i.MX6
    [    1.184447] wait mode is enabled for i.MX6
    [    1.188754] cpaddr = c0880000 suspend_iram_base=c08fc000
    [    1.194182] PM driver module loaded
    [    1.198089] IMX usb wakeup probe
    [    1.201807] add wake up source irq 75
    [    1.209093] IMX usb wakeup probe
    [    1.212619] cpu regulator mode:ldo_enable
    [    1.216839] i.MXC CPU frequency driver
    [    1.243240] VFS: Disk quotas dquot_6.5.2
    [    1.247505] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    1.258016] JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
    [    1.264868] fuse init (API version 7.16)
    [    1.269684] msgmni has been set to 1748
    [    1.275099] alg: No test for stdrng (krng)
    [    1.279381] io scheduler noop registered
    [    1.283318] io scheduler deadline registered
    [    1.287696] io scheduler cfq registered (default)
    [    1.293494] MIPI DSI driver module loaded
    [    1.297687] mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver hdmi
    [    1.304203] mxc_hdmi mxc_hdmi: Detected HDMI controller 0x13:0xa:0xa0:0xc1
    [    1.311126] fbcvt: 1920x1080@60: CVT Name - 2.073M9
    [    1.316028] fb_videomode = 59 1920 1080 5780 328 128 3 32 200 5 2 0 32
    [    1.334770] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines
    [    1.349117] imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~
    5), 5F(6,7)
    [    1.382428] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines
    [    1.415808] Console: switching to colour frame buffer device 160x64
    [    1.463915] mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver ldb
    [    1.470331] _regulator_get: get() with no identifier
    [    1.482050] mxc_sdc_fb mxc_sdc_fb.2: register mxc display driver ldb
    [    1.493247] imx-sdma imx-sdma: loaded firmware 1.1
    [    1.502341] imx-sdma imx-sdma: initialized
    [    1.639468] Serial: IMX driver
    [    1.642643] imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
    [    1.649516] imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
    [    1.655995] console [ttymxc1] enabled, bootconsole disabled
    [    1.667521] imx-uart.3: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX
    [    1.679685] loop: module loaded
    [    1.683222] request BOSSA_CLK IRQ
    [    1.686540] registering IRQ 419 for BOSSAC Arduino erase/reset operation
    [    1.736366] No sata disk.
    [    1.740340] GPMI NAND driver registered. (IMX)
    [    1.745785] vcan: Virtual CAN interface driver
    [    1.750252] CAN device driver interface
    [    1.754090] flexcan netdevice driver
    [    1.757827] FEC Ethernet Driver
    [    1.763228] fec_enet_mii_bus: probed
    [    1.770062] usbcore: registered new interface driver rt2800usb
    [    1.775899] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    1.782562] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
    [    1.789217] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number
    [    1.819074] fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
    [    1.839064] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
    [    1.845319] hub 1-0:1.0: USB hub found
    [    1.849098] hub 1-0:1.0: 1 port detected
    [    1.853191] add wake up source irq 72
    [    1.856891] fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
    [    1.863536] fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number
    [    1.909060] fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
    [    1.939052] fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
    [    1.945247] hub 2-0:1.0: USB hub found
    [    1.949011] hub 2-0:1.0: 1 port detected
    [    1.953445] usbcore: registered new interface driver usbtmc
    [    1.959023] Initializing USB Mass Storage driver...
    [    1.964170] usbcore: registered new interface driver usb-storage
    [    1.970193] USB Mass Storage support registered.
    [    1.975061] usbcore: registered new interface driver usbserial
    [    1.981020] USB Serial support registered for generic
    [    1.986187] usbcore: registered new interface driver usbserial_generic
    [    1.992731] usbserial: USB Serial Driver core
    [    1.997200] USB Serial support registered for debug
    [    2.002213] usbcore: registered new interface driver debug
    [    2.007706] ARC USBOTG Device Controller driver (1 August 2005)
    [    2.013998] g_ether gadget: using random self ethernet address
    [    2.019859] g_ether gadget: using random host ethernet address
    [    2.026435] usb0: MAC 7a:a2:2d:bb:f0:45
    [    2.030291] usb0: HOST MAC 2e:85:14:6d:87:17
    [    2.034566] g_ether gadget: controller 'fsl-usb2-udc' not recognized; trying
    CDC Ethernet (ECM)
    [    2.043302] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
    [    2.049937] g_ether gadget: g_ether ready
    [    2.053948] Suspend udc for OTG auto detect
    [    2.079080] fsl-usb2-udc: bind to driver g_ether
    [    2.084332] mousedev: PS/2 mouse device common for all mice
    [    2.090480] usbcore: registered new interface driver usbtouchscreen
    [    2.097155] Sitronix touch driver 2.9.1
    [    2.101009] Release date: 20120507
    [    2.104788] sitronix_reset_ic
    [    2.228013] send status reg command error (-5)
    [    2.232484] sitronix: probe of 2-0055 failed with error -5
    [    2.238954] snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
    [    2.245645] i2c /dev entries driver
    [    2.249923] Linux media interface: v0.10
    [    2.253954] Linux video capture interface: v2.00
    [    2.289068] usb 2-1: new high speed USB device number 2 using fsl-ehci
    [    2.389643] camera ov5640_mipi is found
    [    2.393895] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as vide
    o16
    [    2.401533] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as vide
    o17
    [    2.409222] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as vide
    o18
    [    2.416891] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as vide
    o19
    [    2.424528] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as vide
    o20
    [    2.432330] vivi-000: V4L2 device registered as video2
    [    2.437474] Video Technology Magazine Virtual Video Capture Board ver 0.8.0 s
    uccessfully loaded.
    [    2.446786] usbcore: registered new interface driver uvcvideo
    [    2.452591] USB Video Class driver (v1.1.0)
    [    2.457580] hub 2-1:1.0: USB hub found
    [    2.461502] i2c-core: driver [mag3110] using legacy suspend method
    [    2.461525] hub 2-1:1.0: 4 ports detected
    [    2.471713] i2c-core: driver [mag3110] using legacy resume method
    [    2.478284] imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (n
    owayout=1)
    [    2.486407] Bluetooth: Virtual HCI driver ver 1.3
    [    2.491344] Bluetooth: HCI UART driver ver 2.2
    [    2.495792] Bluetooth: HCI H4 protocol initialized
    [    2.500605] Bluetooth: HCI BCSP protocol initialized
    [    2.505571] Bluetooth: HCILL protocol initialized
    [    2.510283] Bluetooth: HCIATH3K protocol initialized
    [    2.515248] Bluetooth: Generic Bluetooth USB driver ver 0.6
    [    2.520957] usbcore: registered new interface driver btusb
    [    2.526588] sdhci: Secure Digital Host Controller Interface driver
    [    2.532783] sdhci: Copyright(c) Pierre Ossman
    [    2.537459] mmc0: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA
    [    2.544788] mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver pro
    bed
    [    2.552845] VPU initialized
    [    2.556168] mxc_asrc registered
    [    2.576785] Thermal calibration data is 0x5744e569
    [    2.581599] Thermal sensor with ratio = 180
    [    2.600419] Anatop Thermal registered as thermal_zone0
    [    2.605718] anatop_thermal_probe: default cooling device is cpufreq!
    [    2.613066] usbcore: registered new interface driver usbhid
    [    2.618643] usbhid: USB HID core driver
    [    2.622971] usbcore: registered new interface driver snd-usb-audio
    [    2.629715] mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio
    [    2.635188] Cirrus Logic CS42888 ALSA SoC Codec Driver
    [    2.640450] i2c-core: driver [cs42888] using legacy suspend method
    [    2.646633] i2c-core: driver [cs42888] using legacy resume method
    [    2.652860] mmc0: new high speed SDHC card at address 1234
    [    2.658734] mmcblk0: mmc0:1234 SA08G 7.28 GiB
    [    2.665048]  mmcblk0: p1
    [    2.735511] audio_codec_ac97_cold_reset
    [    2.769195] usb 2-1.3: new high speed USB device number 3 using fsl-ehci
    [    2.821632] Found Audio codec AC97 vt1613, [ID = 5649 - 4123]
    [    2.839828] asoc: vt1613 <-> imx-ssi.0 mapping ok
    [    2.846240] imx_3stack asoc driver
    [    2.851227] asoc: mxc-hdmi-soc <-> imx-hdmi-soc-dai.0 mapping ok
    [    2.857922] ALSA device list:
    [    2.860905]   #0: vt1613-audio
    [    2.863960]   #1: imx-hdmi-soc
    [    2.867220] NET: Registered protocol family 26
    [    2.872263] TCP cubic registered
    [    2.875494] NET: Registered protocol family 17
    [    2.879964] can: controller area network core (rev 20090105 abi 8)
    [    2.886216] NET: Registered protocol family 29
    [    2.890703] can: raw protocol (rev 20090105)
    [    2.894977] can: broadcast manager protocol (rev 20090105 t)
    [    2.900730] Bluetooth: RFCOMM TTY layer initialized
    [    2.905616] Bluetooth: RFCOMM socket layer initialized
    [    2.910765] Bluetooth: RFCOMM ver 1.11
    [    2.914517] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    2.919837] Bluetooth: BNEP filters: protocol multicast
    [    2.925064] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    2.931153] lib80211: common routines for IEEE802.11 drivers
    [    2.936845] Registering the dns_resolver key type
    [    2.941592] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9
     rev 4
    [    2.949711] Bus freq driver module loaded
    [    2.953727] Bus freq driver Enabled
    [    2.959052] mxc_dvfs_core_probe
    [    2.962393] DVFS driver module loaded
    [    2.967674] snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:00
    UTC (0)
    [    2.981625] EXT3-fs: barriers not enabled
    [    5.618114] kjournald starting.  Commit interval 5 seconds
    [    5.618188] EXT3-fs (mmcblk0p1): warning: mounting fs with errors, running e2
    fsck is recommended
    [    5.634440] EXT3-fs (mmcblk0p1): using internal journal
    [    5.639682] EXT3-fs (mmcblk0p1): recovery complete
    [    5.648066] EXT3-fs (mmcblk0p1): mounted filesystem with writeback data mode
    [    5.655156] VFS: Mounted root (ext3 filesystem) on device 179:1.
    [    5.665434] devtmpfs: mounted
    [    5.668459] Freeing init memory: 200K
    [    6.307123] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 385025
    [    6.318626] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 385025
    [    6.330040] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 385025
    [    6.341424] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 385025
    [    6.390545] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 376833
    [    6.402289] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 376833
    [    6.416798] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 376833
    [    6.428477] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 376833
    [    6.442065] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 385025
    [    6.454665] init: mountall main process (1633) terminated with status 1
    [    6.476818] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 385025
    [    6.488887] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 385025
    [    6.500272] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 385025
    [    6.511635] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 385025
    General error mounting filesystems.
    A maintenance shell will now be started.
    CONTROL-D will terminate this shell and reboot the system.
    [    6.634313] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 376833
    [    6.646058] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 376833
    Give root password for maintenance
    (or type Control-D to continue):
    [   12.216123] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 376833
    [   12.238257] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 376833
    [   12.251243] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 385025
    [   12.262703] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 385025
    [   12.274085] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 385025
    [   12.285467] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 385025
    [   12.304884] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 385025
    [   12.316584] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 385025
    [   12.328165] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 385025
    [   12.339612] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 385025
    bash: groups: command not found[   12.354096] EXT3-fs error (device mmcblk0p1):
    ext3_lookup: deleted inode referenced: 385025
    [   12.366213] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 385025
  2. humblehacker
    Apr 7, 2014
    16
    Okay, I tried all over again. Using a new SD Card, downloading the torrent, unpacking in Linux and flashing via DD Command. This time I seemed to get a little further but still short of boot. Connected via HDMI it shows an actual boot sequence dialog, as opposed to last time where it was just a black screen. Unfortunately it seems to hang after failing to open a vncserver.
    Serial Debug output is similar to last time in that it still shows the
    warning, but I was able to get into a login and what appeared to be a root shell. Unfortunately, it won't accept any commands returning the following after inputting startx-
    u@udoobuntu: ~ $ 0;[ubuntu@udoobuntu] ~startx
    [   68.410757] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 409601
    mktemp: failed to create file via template `/tmp/serverauth.XXXXXXXXXX': Input/o
    utput error
    /usr/bin/startx: 155: /usr/bin/startx: xauth: not found
    /usr/bin/startx: 172: /usr/bin/startx: xauth: not found
    xinit: error while loading shared libraries: libxcb.so.1: cannot open shared obj
    ect file: No such file or directory
    /usr/bin/startx: 204: /usr/bin/startx: xauth: not found
    -bash: awk: command not found
    -bash: [: -gt: unary operator expected
    ubuntu@udoobuntu: ~ $ 0;[ubuntu@udoobuntu] ~[  327.105917] EXT3-fs error (device
     mmcblk0p1): ext3_lookup: deleted inode referenced: 409601
    [ 1024.144425] EXT3-fs error (device mmcblk0p1): ext3_lookup: deleted inode refe
    renced: 409601
