UK power cable
Discussion in 'UDOO BOLT' started by Nigel Brown, Apr 20, 2021.
  1. Nigel Brown
    Nigel Brown UDOOer
    Apr 14, 2021
    The Udoo Bolt Gear comes with two power connectors and neither are for the UK, here is how I solved the problem. Using the US cable I cut the connector and wired it like the photo:
  2. NickGR
    NickGR UDOOer
    Jun 23, 2020
    95
    20
    Weird coloring for the ground cable, did you check it with a continuity meter?
  3. Nigel Brown
    Nigel Brown UDOOer
    Apr 14, 2021
    Yes, would not risk it otherwise . And also checked the output and polarity of the PSU. The earth is a greenish colour.
  4. nophead
    nophead UDOOer
    Aug 18, 2015
    87
    14
    Those are the standard US wiring colours, strange but true.
    13A fuse is not appropriate, it should always be a lower rating that the wire, so 5A or 3A, in this case.
    Nigel Brown likes this.
