Unable to boot to GRUB menu
Discussion in 'UDOO BOLT' started by Danilo Cruciani, Jan 1, 2021.
Tags:
  1. Danilo Cruciani
    Danilo Cruciani UDOOer
    May 5, 2020
    I am trying to reach the Grub Menu but pressing either ESC or SHIFT at start-up I reach BIOS or Grub command line.
    Any suggestion?
    Sto provando a visualizzare il menu di Grub, ho provato a premere ESC o SHIFT all'avvio ma entro in BIOS oppure raggiungo la linea di comando Grub.
    Avete suggerimenti?
    Thanks / Grazie
  2. NickGR
    NickGR UDOOer
    Jun 23, 2020
    27
    When BIOS is shown by tapping on the Del key to bring up the BIOS menu. GRUB is brought up with Shift key being pressed as you turn on your computer and keep it pressed until it is shown.
  3. Danilo Cruciani
    May 5, 2020
    Thank you NickGR,
    I tried but pressing Shift at start-up does not bring up the GRUB menu,
    what else can be done?
  4. NickGR
    NickGR UDOOer
    Jun 23, 2020
    27
    Did you made sure you installed GRUB? You have to install Ubuntu or some other distribution which installs GRUB, or yourself by using grub-install utility.
  5. Danilo Cruciani
    May 5, 2020
    Thank you Nick,
    I installed Ubuntu 20.04 on my daughter's Bolt, no other OS, but you say that Ubuntu install GRUB by default,
    am I right?
    Beste regards,
    Danilo.
  6. NickGR
    NickGR UDOOer
    Jun 23, 2020
    27
