Hi everyone, a minor issue: on Linaro, I get Gnome on local login, but when I connect with VNC I get Unity. i can google some more, I confess, but I am afraid to screw up my xstartup. If maybe you already know a solution.. Thanks, Francesco
Re: Unity on VNC, Gnome on login You should setup gnome-classic as the default GUI for VNC connections. I can't remember what file it's in but it is in the user SSH config file. (Only works on Ubuntu up to 12.04. Everything after that is pure Unity.) Quick Google found: http://askubuntu.com/questions/172384/v ... boot-12-04 Method should be the same for 11.10. Thanks, EBrown
Re: Unity on VNC, Gnome on login YES! Thank you. The file is here: Code: ~/.vnc/xstartup I commented this line: Code: /etc/X11/Xsession And added this one: Code: gnome-session --session=gnome-classic & So the resulting file on Linaro 12.10 after standard VNC server install (tutorial) and this little mod is now: Code: #!/bin/sh xrdb $HOME/.Xresources xsetroot -solid grey #x-terminal-emulator -geometry 80x24+10+10 -ls -title "$VNCDESKTOP Desktop" & #x-window-manager & # Fix to make GNOME work export XKL_XMODMAP_DISABLE=1 #REMOVED #/etc/X11/Xsession #ADDED gnome-session --session=gnome-classic & Thanks, UDOO rocks.
