Update openCV2.4.11 in IMX6Q with udoobuntu 1
Discussion in 'General Discussion' started by ime0422, Nov 30, 2015.
  1. ime0422
    ime0422 New Member
    Nov 16, 2015
    Hello everyone
    I've a problem.
    I want to install opencv2.4.11 in udoobuntu
    I fellow this article
    After I finish cmake this step , I make the file
    I suffer this error
    In file included from /usr/include/GL/glx.h:45:0,
    from /home/ubuntu/Desktop/opencv-2.4.11/modules/highgui/src/window_QT.cpp:59:
    /usr/include/GL/gl.h:162:17: error: conflicting declaration 'typedef double GLdouble'
    /usr/include/qt4/QtOpenGL/qgl.h:85:17: error: 'GLdouble' has a previous declaration as 'typedef GLfloat GLdouble'
    In file included from /usr/include/GL/gl.h:2085:0,
    from /usr/include/GL/glx.h:45,
    /usr/include/GL/glext.h:5327:19: error: conflicting declaration 'typedef ptrdiff_t GLintptr'
    /usr/include/GLES2/gl2.h:38:26: error: 'GLintptr' has a previous declaration as 'typedef khronos_intptr_t GLintptr'
    /usr/include/GL/glext.h:5328:19: error: conflicting declaration 'typedef ptrdiff_t GLsizeiptr'
    /usr/include/GLES2/gl2.h:39:26: error: 'GLsizeiptr' has a previous declaration as 'typedef khronos_ssize_t GLsizeiptr'
    In file included from /usr/include/qt4/QtCore/qtconcurrentrun.h:50:0,
    from /usr/include/qt4/QtCore/QtCore:123,
    from /usr/include/qt4/QtOpenGL/QtOpenGL:3,
    from /home/ubuntu/Desktop/opencv-2.4.11/modules/highgui/src/window_QT.h:46,
    from /home/ubuntu/Desktop/opencv-2.4.11/modules/highgui/src/window_QT.cpp:47:
    /usr/include/qt4/QtCore/qtconcurrentrunbase.h: In member function 'QFuture<T> QtConcurrent::RunFunctionTaskBase<T>::start() [with T = int]':
    /usr/include/qt4/QtCore/qtconcurrentrun.h:84:111: instantiated from 'QFuture<T> QtConcurrent::run(T (*)(Param1, Param2), const Arg1&, const Arg2&) [with T = int, Param1 = int, Arg1 = int, Param2 = char**, Arg2 = char**]'
    /home/ubuntu/Desktop/opencv-2.4.11/modules/highgui/src/window_QT.cpp:348:64: instantiated from here
    /usr/include/qt4/QtCore/qtconcurrentrunbase.h:84:42: warning: declaration of 'future' shadows a member of 'this' [-Wshadow]
    make[2]: *** [modules/highgui/CMakeFiles/opencv_highgui.dir/src/window_QT.cpp.o] Error 1
    make[1]: *** [modules/highgui/CMakeFiles/opencv_highgui.dir/all] Error 2
    make: *** [all] Error 2
    Then I found some solution,it's tell me install libqt5opengl5 & libqt5opengl5-dev
    And I enter this instruction.
    sudo apt-get install libqt5opengl5 libqt5opengl5-dev
    It jump up this error
    E: Unable to locate package libqt5opengl5
    E: Unable to locate package libqt5opengl5-dev
    Please teach me to slove this problem , Thank you!!
  2. Andrea Rovai
    It tells you that because the package is missing. You should recompile the kernel to get it work.
  3. ime0422
    ime0422 New Member
    Nov 16, 2015
  4. Andrea Rovai
    Since you want to install it on UDOObuntu 1 and given that is UDOObuntu 1 compatible as it seems, yes you can follow that guide.
