upload to curie/arduino 101 doesn't work !
Discussion in 'UDOO X86' started by zugy, Jun 23, 2017.
  1. zugy
    zugy New Member
    Oct 31, 2013
    I can't upload anything to curie/arduino 101 either way I tried.
    I'm using last firmware on udoox86, last local arduino IDE (1.8.3)
    I've been trying from Ubuntu and Windows. From arduino local or web ide.
    On Windows and local IDE, I get the following error :
    Starting download script...
    Flashing is taking longer than expected
    Try pressing MASTER_RESET button
    ERROR: Timed out waiting for Arduino 101 on COM3
    With the web ide, I get the following error :
    Restarting in bootloader mode
    Get port list before reset
    [COM3]
    Touching port COM3 at 1200bps
    Reset before upload: 1200bps Touch: Open port COM3: Invalid serial port
    I would like to know (first) if Windows device manager should see the arduino like with a normal usb/serial connection ?
    The web IDE "sees" the 101 but can't upload.
    Any help welcome
    Thanks,
    Christophe
  2. x1800MODMY360x
    x1800MODMY360x Member
    Mar 29, 2017
    55
    Did you press the reset button when the message pops up?
  3. zugy
    zugy New Member
    Oct 31, 2013
    Yes I did, but no solution this way.
  4. zugy
    zugy New Member
    Oct 31, 2013
    ok, can someone tell me if the device manager show the arduino connected to port com in Windows ?
    And when I press the master reset button the device manager refreshs and shows an unknown device : UDOO X86.
  5. waltervl
    I tried from Ubuntu, did the udev rule action and got the same error message.
    Then I rebooted the system, pushed the Arduino master reset button, waited a couple of seconds and uploaded the blink example. Now the message appeared about updating BLE firmware and the sketch uploaded.
    After that no errors were shown.
    Edit: The BLE Firmware update is part of the Arduino 101 Core 2.02 release: https://forum.arduino.cc/index.php?topic=467970.0
  6. waltervl
    I see the procedure changed again (due to Arduino changes):
    Upload Procedure
    Some Linux distributions need to be configured to to gain upload permissions.
    Inside the Arduino 101 core you can find a script to allow the user to use the serial device. Using the latest Arduino 101 core package v2.0.2 run the script with this commands:
    chmod +x ~/.arduino15/packages/Intel/hardware/arc32/2.0.2/scripts/create_dfu_udev_rule
    sudo ~/.arduino15/packages/Intel/hardware/arc32/2.0.2/scripts/create_dfu_udev_rule
    bpr and Markus Laire like this.
  7. MarcLaos
    MarcLaos New Member
    Jun 14, 2017
    I am running windows 10 - 64 bit with arduino IDE (1.8.3).
    I have the same problem.
    Can't upload anymore. A few times it worked but now still gets that error
    how to let it run on a decent way?
  8. tortuga
    tortuga New Member
    Jul 31, 2017
    I have the same problem too.
    I have reflash the EFI firmware to the default settings. But the problem has not been solved.
    Has anyone worked with the Arduino 101 on Windows 10?
  9. connon neal
    connon neal New Member
    Oct 26, 2017
    do anyone know how to fix this running Ubuntu 17.04
  10. cagiva
    cagiva UDOOer
    Aug 28, 2017
    15
    I'm having the same problem, was anyone able to find a workaround?
