hey guys after i download and install vncserver on udoo quad linaro ubuntu 12.04 lts i cant log in to udoo directly and remote i can only log in into guest session i have format my sd-card 2 times now did any one have same problem or you have a solution
I have tried the same guide step by step and after reboot I had the same result. I could only log in as guest but cannot continue because need a password for authentication which I dont know... If anyone got the solution please send it!!!!! I will try to make a new bootable disk.....
when you say guest session you mean with guest access and you cant do anything? That is a strange one, let us know if the new image helped
Hello, after copying again the image to the mini disk, the Udoo functions normally. However when I try to install TightVNCServer got the same problem. Rebooting has as result a guest only log in that cannot accept any password. Closing the log in window I got console environment as guest. Off course trying sudo -s cannot work cause doesnt accept any password (root)...
