What is SE Blank PELE?
Discussion in 'UDOO NEO' started by HolyGrayst, Nov 17, 2016.
  1. HolyGrayst
    HolyGrayst New Member
    Nov 17, 2016
    My preloaded 8GB SD Card bought from Udoo neo appear as Se blank pele with no driver to install. is there any way to repair?
    I suspect something when wrong after i try to boot using that bootable sd card video.
  2. Andrea Rovai
    What you mean by blank PELE? There's no need for drivers to install. Are you saying maybe that you've attached the Neo to the PC and your PC doesn't see the Neo?
  3. Chiheb
    Chiheb New Member
    Jul 22, 2017
    15
    Hi Andrea, I have the same problem with my board Neo. When I attached it to PC, can't be see it as RNDIS Kitl. The PC detect it as 'SE blank PELE', so I can't use the USB Direct Connection.
  4. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    158
    17
  5. jas-mx
    jas-mx Active Member
    Dec 31, 2013
    407
    118
    This occurs when NEO can't find valid image on the SD card to boot from and reverts usb boot loading.
    Chiheb likes this.
  6. Chiheb
    Chiheb New Member
    Jul 22, 2017
    15
    Can you give me a link for another udoobuntu image?
  7. jas-mx
    Dec 31, 2013
    407
    118
    The image you have using should work, as I mentioned in the other thread its easier to debug the problem by attaching to the uart console to get the boot output.
  8. Chiheb
    Chiheb New Member
    Jul 22, 2017
    15
    Try to use another 8GB SD card
