I have searched the web and come up with the following ssh logins for udoobuntu: root - ubuntu / udooer - udooer / ubuntu - ubuntu None of them work. What is the password for root? Please anyone. Thanks Bill
Password of root should be "ubuntu" If you fail to login (especially with default user udooer) it looks like something went wrong with installing. How do you logon? Remote with ssh, Vnc? Or just with a connected monitor, because then you should not have to enter a password after boot.
WOW. OK, I wipe out partitions, reinstall oodubuntu - same problem Will not take any of the passwords above for any of the accounts. I am lost. I just want to ssh into udoobuntu.....
Just a couple of things to check: 1. You have a Udoo Quad, yes? 2. Did you download the image for the Quad here: https://www.udoo.org/downloads/ 3. Can you ping the Quad on the IP address it is given by the router? 4. Can you connect to the Web Control Panel (put the IP address of the Quad in a browser address field) ? https://www.udoo.org/docs/Basic_Setup/Web_Control_Panel.html Edit: You should download image following image for the Quad, did you download that one?: UDOObuntu 2.1.4 (Ubuntu 14.04 LTS)
