Beta Firmware Issues
Discussion in 'UDOO BOLT' started by Xeyrruken, Nov 6, 2019.
  1. Xeyrruken
    Xeyrruken UDOOer
    Jun 6, 2019
    31
    Hello, I have installed the Beta FIrmware sent via Email C400RC13.105, it is getting stuck after finishing main block verification, nothing else like the instructions says in the PDF.
    I have restarted the bolt and now it is uber slow, it takes like 2 minutes to boot the bios screen and like 5 minutes to load windows.
    Can't get past yellow line, it says done and all but nothings happens after that one
    EFI mode throws me a warning like the USB drive doesn't contain the .efi file
  2. Xeyrruken
    Xeyrruken UDOOer
    Jun 6, 2019
    31
    Password: udoobolt
  3. Xeyrruken
    Xeyrruken UDOOer
    Jun 6, 2019
    31
    Additionally when i i tried first bios_updater_x64 C400RC13.105 i got a BSOD
  4. Micka41
    Micka41 UDOOer
    Aug 26, 2019
    Same problem :
    It is very, very slow: my Bolt takes 2 minutes to start whereas before in less than 30 seconds Ubuntu was available.
    For the fan, it is always 100%...
  5. Deluxe
    Deluxe UDOOer
    Aug 13, 2019
    11
    Can you see USB-C and Embedded Controller firmware in bios? I had the issue of very slow startup after updating the firmware too, and I had "Unknown" in version of both USB-C and Embedded controller firmwares until after I powered the Bolt down and unplug the power. After that I could see firmware versions again and Bolt initialized much faster.
    I still have problem with fan which goes to 100% after Bolt shuts down (orange power led).
  6. Xeyrruken
    Xeyrruken UDOOer
    Jun 6, 2019
    31
    @Micka41 @Deluxe
    I manage to Install the bios as expected, to fix the slow performance, after the reboot, turn off the bolt and unplug from power and press for 15 seconds the power button. After that everything was back to "normal" I feel it was a little bit faster on previous firmware.
  7. Zgembo
    Zgembo UDOOer
    Sep 21, 2019
    30
    12
    Same here, after 2-3 reboots following flashing, only full power cycle would restore things back to "normal"...
  8. FastFreddi
    FastFreddi UDOOer
    Jun 20, 2017
    Thanks for this. Things were really slow with the BIOS and boot. USB-C Port controller menu option said unknown for silicon ID/ Bootload/ Firmware 1 & 2. Monitor hardware parameters and settings option cause the system to become unresponsive for a few moments with nothing showing in that menu section. After power cycle USB-C show version info and Monitor Hardware show temp/volts and fan RPM
  9. evaloverde
    Apr 29, 2019
    129
    35
    Hey guys,
    I've asked the people that are taking care of the BIOS, and it's normal for the update to take a few cycles to be complete.
    Make sure to let Ettore know about any feedback.
    Thank you for volunteering guys!
  10. Zgembo
    Zgembo UDOOer
    Sep 21, 2019
    30
    12
    Yes, it is quite normal few reboot cycles are required. However, it is pretty abnormal that power cycle is required. Ettore and the crew should totally be aware of this.
  11. zidamouge
    zidamouge UDOOer
    Jul 10, 2019
    Finally got the rc13.105 firmware installed and so far I am liking the availability to keep the fan running. After looking at the settings the main thing i could see a potential of people wanting is AC0 having the availability to be a much lower temperature. Just wanted to mention before a release candidate becomes official.
  12. zidamouge
    zidamouge UDOOer
    Jul 10, 2019
    after a small amount of testing fan control still seems to be 100% or off or 0% the ramp up speed is nice though. the setting state fan duty cycle % as a speed for temps above AC1 but if fan duty cycle % = less than 100% the fan is off till it hits the temp stated by AC0.
  13. Zgembo
    Zgembo UDOOer
    Sep 21, 2019
    30
    12
