Connect 2 external devices to A9 via UART
Discussion in 'UDOO NEO' started by DezertRozez, Mar 9, 2018.
  1. DezertRozez
    DezertRozez New Member
    Mar 9, 2018
  2. jas-mx
    jas-mx Active Member
    Dec 31, 2013
    407
    118
    If your not using UART5 (or the pins) on the M4 side then you can reallocate it to the A9 side, however I'm not sure if this is possible through the device tree editor. If not then you need to 'hack' the dts files, recompile and deploy.
    Alternatively you can plugin a usb to serial adapter (eg like a CP1202) to gain another serial port.
  3. DezertRozez
    Mar 9, 2018
    Hi Jas-mx, Thanks so much for the suggestion.
  4. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    158
    17
    @DezertRozez I would be very interested to hear if you did it reallocating UART5.
