Help using NEO UART
Discussion in 'UDOO NEO' started by Tengoles, Jun 18, 2017.
  1. Tengoles
    Tengoles New Member
    Nov 23, 2016
    14
    Hello, I want to use a UART on the board to communicate the NEO with a external device using this simple python script that was done to make this task on a beaglebone black:
    import Adafruit_BBIO.UART as UART
    import serial
    UART.setup("UART1")
    ser = serial.Serial(port = '/dev/ttyO1', baudrate=9600)
    ser.close()
    ser.open()
    while ser.isOpen():
    x = ser.readline()
    print x
    ser.close()
    I believe that the only thing that is needed for this to work is adapting the UART setup part at the beginning. Any help with that?
    Tengoles likes this.
  3. Tengoles
    Tengoles New Member
    Nov 23, 2016
    14
    Okay, let's see... First of all, I used the device tree editor and now it looks like this:
    [​IMG]
    Can I assume that the pins have this functions:
    [​IMG]
    Also did the patch mentioned on your link and changed my code to this:
    import serial
    ser = serial.Serial(port = '/dev/ttymxc5', baudrate=9600)
    ser.close()
    ser.open()
    while ser.isOpen():
            x = ser.readline()
            print x
    ser.close()
    Should I be good to go now?
  4. waltervl
    Edit: Did not read well, you patched... :)
    Yes you are OK.
  5. Tengoles
    Tengoles New Member
    Nov 23, 2016
    14
    Worked perfectly! thanks
  6. waltervl
    just to inform you that in Udoobunto 2.1.3, Release date 19-jun-2017 the patch for UART6 has been implemented.
    See also [SOLVED] I2C slow
