DHCP server setup issues
Discussion in 'Linux Ubuntu' started by TAC, Aug 13, 2018.
  1. TAC
    TAC New Member
    Aug 13, 2018
    Trying to setup isc-dhcp-server on UDOO Neo.
    I've setup the following files
    /etc/dhcp/dhcpd.conf:
    default-lease-time 86400;
    max-lease-time 8640000;
    log-facility local7;
    subnet 192.168.7.0 netmask 255.255.255.252 {
    option routers 192.168.7.2;
    option subnet-mask 255.255.255.252;
    range 192.168.7.1 192.168.7.1;
    subnet 192.168.100.0 netmask 255.255.255.0 {
    option routers 192.168.100.1;
    option subnet-mask 255.255.255.0;
    range 192.168.100.10 192.168.100.20;
    /etc/default/isc-dhcp-server:
    # Defaults for isc-dhcp-server initscript
    # sourced by /etc/init.d/isc-dhcp-server
    # installed at /etc/default/isc-dhcp-server by the maintainer scripts
    # This is a POSIX shell fragment
    # Path to dhcpd's config file (default: /etc/dhcp/dhcpd.conf).
    #DHCPD_CONF=/etc/dhcp/dhcpd.conf
    # Path to dhcpd's PID file (default: /var/run/dhcpd.pid).
    #DHCPD_PID=/var/run/dhcpd.pid
    # Additional options to start dhcpd with.
    # Don't use options -cf or -pf here; use DHCPD_CONF/ DHCPD_PID instead
    #OPTIONS=""
    # On what interfaces should the DHCP server (dhcpd) serve DHCP requests?
    # Separate multiple interfaces with spaces, e.g. "eth0 eth1".
    INTERFACES="eth0"
    /etc/network/interfaces:
    # Loopback network interface
    auto lo
    iface lo inet loopback
    # Primary network interface
    auto eth0
    #iface eth0 inet dhcp
    iface eth0 inet static
    address 192.168.100.0
    gateway 192.168.100.1
    # USB OTG connection
    allow-hotplug usb0
    iface usb0 inet static
    address 192.168.7.2
    Running dhcpd it looks like something is not configured correctly
    with the icmp socket and LPF error.
    I also had to keep using chmod to allow write access to the lease file folder,
    this seems to get reset to read only on restart
    Console output:
    udooer@udooneo:~$ dhcpd
    Internet Systems Consortium DHCP Server 4.2.4
    Copyright 2004-2012 Internet Systems Consortium.
    All rights reserved.
    For info, please visit https://www.isc.org/software/dhcp/
    unable to create icmp socket: Operation not permitted
    Wrote 0 leases to leases file.
    No subnet declaration for wlan0 (no IPv4 addresses).
    ** Ignoring requests on wlan0. If this is not what
    you want, please write a subnet declaration
    in your dhcpd.conf file for the network segment
    to which interface wlan0 is attached. **
    Open a socket for LPF: Operation not permitted
    udooer@udooneo:~$
    Any suggestions? Thanks
  3. TAC
    TAC New Member
    Aug 13, 2018
    Got it to work using sudo dhcpd, provides ips to external clients
    added it to crontab "@reboot dhcpd" starts up no problem
  4. Carver kLeo
    Carver kLeo New Member
    Jan 14, 2021
    Hey TAC, you can deal with a large number of scopes with the help of the DHCP Scope Monitor utility of the OpUtils software as it guides you to analyze the DHCP Scopes to check the available IP Address count in all of them. When the available IP Address count falls below a particular number, the results are shown in red color. You can arrange the monitoring of scopes by going for these steps. In the start just tap the Settings link to open the settings page and choose the Scheduler tab. Go for https://appuals.com/manage-dhcp-scopes/ this site to find more. Now alter the Status to Enabled and specify the interval to perform the scan:/p> At the end just tap Schedule to save the changes.
