Power supply compatibility list
Discussion in 'UDOO BOLT' started by Flash2k6, Apr 17, 2019.
  1. Gerry Havinga
    Gerry Havinga UDOOer
    Jul 25, 2019
    Correction: make called Zedar
  2. Tatsugen
    Tatsugen New Member
    Aug 2, 2019
  3. Xeyrruken
    Xeyrruken UDOOer
    Jun 6, 2019
    38
    I'm using the Dell D6000 USB 3.1 and USB-C Dock, it is working flawlessly, I have additional ports and I'm only using one USB-C on the bolt.
  4. jfs10
    jfs10 UDOOer
    Apr 16, 2019
    22
    The power supply is not the cause of my problem. The last time it happened, I felt the power supply, and it was barely warm.
  5. anlumo
    anlumo UDOOer
    38
    The AUKEY PA-Y12 power supply is confirmed not working.
  6. someone_passingby
    someone_passingby UDOOer
    Oct 3, 2019
    24
    Sharing pricey but minimalistic adapters (recommended to those who value minimalism over money):
    USB-C option: Innergie 60C USB-C Laptop Adapter (Int'l)
    http://www.myinnergie.com/us/product/136
    To Buy: https://amzn.com/B07GBXMN78
    DC Barrel option (HP laptop tip): Innergie 65U Laptop Adapter (Int'l)
    http://www.myinnergie.com/us/product/145
    To Buy (Warning: I purchased Int'l version, but this is US only version): https://amzn.com/B07N83V64F
    I can every single eletronic device I have including Udoo Bolt with the above.
    Recommended for those who want to have one/two charger(s) for all, but it/they come(s) at a price.
  7. R41
    R41 UDOOer
    Oct 18, 2019
    Hi UDOO, need help/advice here. I think I fried my UDOO BOLT. Not sure if the adapter is faulty or the mobo is faulty.
    See HDMI CN20 area. You can see that spot looks burnt.
    [​IMG]
    My whole house blacked out the moment i turn the power on.
    The saddest part, I didn't get to use this board as I powered it for the very first time.
    This is the AC Adapter i used (shown below).
    [​IMG]
    Any advice, guys? I don't know whether to cry or live with heart ache.
  8. ehf
    ehf UDOOer
    Oct 18, 2019
    Will a 90W HP Envy 17 series Power Supply that has 4.5*3.0 light blue work on the Bolt V8 without trouble?
  9. ccs_hello
    536
    194
    That burnt area is a zero ohm resistor (serving as a poorman's fuse) on the HDMI port.
    It seems that the power surge came in from the HDMI cable (believe it or not, I had heard a similar story from a friend that thunder came thru HDMI cable; in his case, the fancy HDTV was a goner...)
  10. ccs_hello
    536
    194
    Does it say 19V 4.74A (or similar)? If true, and with a light-blue plug, most likely it will work. YMMV
  11. fxlevy
    fxlevy UDOOer
    May 23, 2019
    19
  12. ej_1090
    ej_1090 UDOOer
    Nov 9, 2019
    Currently using Dell DA130PE1-00 130W power supply with a Dell power supply to HP power supply adapter
    [search string]
    "DC Power Charger Converter Adapter Cable 7.4mm To 4.5mm"
  13. DJVT
    DJVT UDOOer
    Nov 28, 2019
    16
    Hello,
    currently I am using an apple 87 W USB-C power supply which works fine for now. It can also be run in line with a dongle to get more USB ports. For later use I have a battery managment system called openUPS. But for being able to use it I need to get a matching power plug, which I am having a hard time finding. Anyone knowing a source?
  14. m0j0
    m0j0 UDOOer
    Feb 18, 2020
    11
    I run the Bolt with a Dell 130W power adapter which was lying around. This power adapter delivers 19.5V and some generous 6.67A providing a huge buffer of power. And it is slim and the cable can be wrapped nicely to store the adapter.
    Dell 6TTY6
  15. Tylerlooney92
    Tylerlooney92 New Member
    May 14, 2020
    Hi every one, im new to the forum, but i had a question about the power delivery options using the usb type c. Is it possible to use a usb type c mobile battery bank like cell phones use to power the udoo bolt v8. I want to invest in the bolt but need it to be mobile and easy to maintain with out having to go through a million break out circuits just to get power from a mobile power bank to the bolt when i could just hook it up with the c cord and battery bank. So have any of you used a type c battery bank to power the bolt before?
  16. ccs_hello
    536
    194
    You'll need a USB-C PD battery pack with the proper spec (19V 3A or 20V 3A).
    Lower ones (like what you've stated) won't work.
    Have you read through this thread, such as this one?
    https://www.udoo.org/forum/threads/power-supply-compatibility-list.27218/#post-53304
  17. MattB
    MattB New Member
    May 31, 2019
    Sure. I run mine from a Zendure Supertank occasionally. I couldn't give you a runtime on it though, since I haven't done extended runs like that. It's a little pricey, but I'm sure there are cheaper options out there. As noted above, and in the documentation, the battery will need to support the 20V 3A power profile.
  18. rushboardtechuk
    rushboardtechuk UDOOer
    Jun 14, 2019
  19. zhangster
    zhangster UDOOer
    Apr 25, 2020
    is there a button or a pin that needs to be flipped to make the UDOO Bolt work with USB-C? I'm using a 20V 3A USB C Charger / gen2 cable and only the arduino light blinks on and off when i plug in the USB C Cord
  20. ccs_hello
    536
    194
    It's automatic (actually automagic) when a proper USB-C power adapter and a correct USB-C cable are used.
    When the right adapter and right cable is used, it's magic!
    When anything that is out of spec, NO, it won't work and you won't have a clue why. That's the ugly side of that magic coin.
    There is no layman tool (can try WEB-U2 tester) or anything visual that can show the user it definitely will work. The issue fall under the USB-C design (overly complex and too many moving parts) and the continuous push to say "it's universal" but in reality it is not.
    This is why there is the list in this thread
    and also I always tell people try to use that DC 19V jack to verify BOLT is working properly first, (then spend your spare time to wrestle with the ugly USB-C PD scheme.)
