Seeing nothing after first time turning on Udoo
Discussion in 'UDOO 101' started by zhunping, Mar 14, 2015.
  1. zhunping
    zhunping New Member
    Feb 10, 2015
    Hi, I got Udoo and followed the get-started instructions (http://www.udoo.org/getting-started/#tab2) to step 3:
    After I turned on the Udoo (the lights on the board lighted up), I saw nothing on the monitor. Is there anything I can do to debug it?
    I'm connecting it to a Apple 27' thunderbolt display through a HDMI-MDV adapter. I installed Linux Quad version on the SD card. By the way Mac does not recognize the SD card after I installed the OS on it.
    Wonder if there is anything I did wrong? Thanks a lot!!!
  2. ivan
    ivan Member
    Mar 8, 2015
    77
    I dus encouter the same probleem.
    i geve several monitors, and a fresh installation Works inkt with Ine monitor, an a tv with HDMI input.
    From there i hope hou can adjust via udoo config the proper monitor.
    It is normaal that hou os grom Apple cant read the udoo os, totaly defferent os.
  3. Andrea Rovai
    Hello all,
    1) @zhunping, have you tried also other HDMI monitor to exclude other problems?
    2) @ivan: try to verify the sha1 of the image you downloaded. Anyway, try to reflash the OS and verify if now it works.
    Cheers!
  4. zhunping
    zhunping New Member
    Feb 10, 2015
    @Andrea Roval. thanks for the reply. I have not tried any other HDMI monitors, I'm thinking about ordering an Udoo monitor.
    By the way, I followed the trouble-shooting post (http://www.udoo.org/faq-items/why-my-udoo-wont-boot/) and connected Udoo to Mac using serial port. It returned nothing which falls into the 4-th category. It says it means the image was not correctly flashed. I tried a few times always got the same problem. I think the SD card is ok because the first time I plugged it into the Mac I can read the content on it.
    I wonder if buying an Udoo monitor sounds like the best way to try to solve it at this point? Thanks!
  5. zhunping
    zhunping New Member
    Feb 10, 2015
    @Andrea, never mind, just ordered a 7" touch, will see if it works
  6. Andrea Rovai
    Hi zhunping,
    any news regarding your problem?
  7. zhunping
    zhunping New Member
    Feb 10, 2015
    Hi Andrea,
    I've got the screen and I plug it in, it still shows nothing. So what did is:
    1. flushed Ubuntu onto a 8gb microSD following the instructions in the getting started area.
    2. connected power and the 7' screen to Udoo
    nothing shows up. I haven't tried to connect keyboard / mouse / network to it yet, but I guess it should already boot up and show something. Do you think I need to put more than just the microSD card + power + monitor to see the system booting?
    Thanks.
  8. TomFreudenberg
    TomFreudenberg Member
    May 12, 2014
    59
    Hi, if you use a serial/usb connection from your UDOO to your MAC and e.g. the MAC SerialTools App, you should be able to connect to the very first boot prompt. So please use setting of 115200-N-8-1 and connect BEFORE powering. The SerialPort for the device should be SLAP_USBtoUART
    http://www.w7ay.net/site/Applications/Serial%20Tools/
    If you plug-in POWER you should IMMEDIATLY see the boot process
    If this does not happen, your SD-CARD ist NOT FLASHED correctly.
    Most of the time, the BOOTLOADER is wrong. Please check wether you have a DUAL or a QUAD board and reflash at least the bootloader.
    Download appropriate U-BOOT from
    http://www.udoo.org/downloads/#tab2
    Follow guide to update U-BOOT:
    see paragraph "Install the U-Boot" near end of the page
    http://www.elinux.org/UDOO_creating_a_b ... d_binaries
    Whatever OS you want to start, your SD-Card must begin with the BOOTLOADER and the debug output.
    Good luck
    Tom
  9. TomFreudenberg
    May 12, 2014
    59
    Attention: Jumper J1 has be closed for the debugging output
  10. team_udoo
    team_udoo Administrator Staff Member
    Apr 29, 2013
    You must configure the u-boot to work with LVDS screens, as the default video output is set to HDMI.
    Since in your case it fails, my advice is to configure it via SSH:
    - Connect UDOO via ethernet to your router
    - Discover your UDOO's IP like shown in this tutorial http://udoo.org/tutorial/find-ip-address/
    - Connect via SSH, like in this tutorial http://udoo.org/tutorial/connecting-via-ssh/ (user root, password ubuntu)
    - Set LVDS output, with UDOO's configuration tool from command line:
    udoo-config boot_video ldb LDB-WVGA
    - Then reboot and enjoy your 7'' panel!
    Let me know how it goes
  11. zhunping
    zhunping New Member
    Feb 10, 2015
    Hi Tom and Team_udoo,
    Thanks for your replies! Let me try it again
  12. zindhu
    zindhu New Member
    Sep 5, 2015
    Hi andrea,
    I have problem with him, but i these case i make with windows. Can help me to solve it?
    Sent from my SM-N900 using Tapatalk
  13. Andrea Rovai
    Hi zindhu,
    could you better specify your problem? What do you make with windows?
    Cheers
