Supplying power to 3.5 inch hdd
Discussion in 'UDOO X86' started by Gronis, May 6, 2017.
  1. waltervl
  2. lukashann
    lukashann New Member
    Dec 21, 2017
    Oh right, I see, thank you so much. But if I just rig up a sata power connector to CN12 which has 12V, GND, GND, 5V even in that order it should work, right?
  3. waltervl
    It could work if your drive does not use too much current. You better hook up the 12V for SATA directly from an external 12V source.
  4. lukashann
    Dec 21, 2017
    What if I just use a higher current power supply? say 5A instead of 3A. Could I break the Udoo by sending too much current through the 12V rail?
  5. waltervl
    Yes, you can take that risk and destroy your board if it goes wrong. You better make a power wire for Udoo and HDD like someone did and explained earlier in this thread. Costs to make are nothing compared to a destroyed Udoo board.
    Udoo did not connect that SATA 12V connector for a reason (overload the 12V rail)
  6. sirrab
    sirrab UDOOer
    Jul 26, 2014
    264
    32
    That will work with 3.5" drives, assuming the UDOO has the current available.
  7. sirrab
    sirrab UDOOer
    Jul 26, 2014
    264
    32
    Nevermind!
  8. Ndrandloop
    Ndrandloop New Member
    Jan 9, 2018
    On page 17 of the manual I find written that the maximum consumption in stress test is
    1008mA 1020mA 906mA
    so we should be able to associate a hdd3.5
    So I was thinking, if I took the 12v from the fan connector? It's possible?
  9. ccs_hello
    536
    194
    No.
    1) It is not always on, and
    2) You don't want to burn that tiny MOSFET (save pennies and risk hundreds)
    Ndrandloop likes this.
  10. Ndrandloop
    Jan 9, 2018
    I have a Seagate Barracuda 3TB 3,5 inches, plugged by USB3 rack (https://www.amazon.it/gp/product/B0725Z3BZV) but i cannot see it in windows 10. It was seen as "EXTERNAL USB3.0 SCSI DISK DEVICE" in device list.
  11. ccs_hello
    536
    194
    3139U3 needs a standalone/separate 12V external DC power feed.
    Per datasheet http://www.orico.cc/goods.php?id=6478
    under Win 10, USAP protocol is supported. Not sure Win 10 needs to fetch the driver for that or not.
    ccs_hello
