Trying to enable i2c1
Discussion in 'UDOO QUAD' started by vudoo, Aug 4, 2017.
Tags:
  1. vudoo
    vudoo New Member
    Jun 14, 2017
    17
    I am trying to enable i2c1 in udoo quad. The pins are 20 and 21 which translates to EIM_D21, EIM_D28.
    I edited imx6qdl-udoo.dtsi to enable i2c1.
    &i2c1 { // sensors
      clock-frequency = <100000>;
      pinctrl-names = "default";
      pinctrl-0 = <&pinctrl_i2c1>;
      status = "okay";
    Then I edited imx6qdl-udoo-externalpins.dtsi to disable exporting as GPIO. I commented out those lines
    //MX6QDL_PAD_EIM_D28__GPIO3_IO28 0x80000000 // {{external-gpio-20}}
    //MX6QDL_PAD_EIM_D21__GPIO3_IO21 0x80000000 // {{external-gpio-21}}
    //&i2c1 {
    //  clock-frequency = <100000>;
    //  pinctrl-names = "default";
    //  pinctrl-0 = <&pinctrl_i2c1>;
    //  status = "disabled";
    pinctrl_spdif: spdifgrp {
      fsl,pins = <
        MX6QDL_PAD_GPIO_19__SPDIF_OUT 0x1b0b0
    //    MX6QDL_PAD_EIM_D21__SPDIF_IN 0x1b0b0
    Is this correct? Am I missing something?
    I get a lot of messages complaining about audio in logcat.
    Can you help?
  2. vudoo
    vudoo New Member
    Jun 14, 2017
    17
    Ping. I guess I will give up on this forum. It seems that I am posting to myself.
  3. waltervl
    2,302
    575
  4. vudoo
    vudoo New Member
    Jun 14, 2017
    17
    This is not easier. You cant have audio output enabled if you go this way.
  5. waltervl
    2,302
    575
    I am not completely sure, but you cannot have and SPDIF and I2C functionality on the same pin on the same time, you have to choose.
    Perhaps use the other I2C bus (SDA1, SDL1) on the Arduino side?
  6. waltervl
    2,302
    575
  7. vudoo
    vudoo New Member
    Jun 14, 2017
    17
    I think SDA1, SCL1 are not available for use on the i.MX6. The post you sent me is contains outdated information. The device tree/kernel has changed since then.
    Also I am running Android and the problem I noted before is related to Android. Maybe I got i2c1 working but Android is expecting there something that it can find, like spdif.
  8. waltervl
    2,302
    575
    The post I linked to is outdated but stll valid.
    What do you need? An I2C connection? Then you probably (I am not an expert on PinMuxing) have to switch of SPDIF in imx6qdl-udoo.dtsi and imx6qdl-udoo-externalpins.dtsi completely (not just outcomment 1 pin)
